Polarity indicator removal/replacement 1980 FC33
03-15-2009, 06:54
Trying to pull the polarity indicator to cure the GFCI trip problem. Pulled the
screws easy enough, but it doesn't want to come out. No rear access as far as I can tell. Managed to destroy the voltmeter on one in my clumsy attempts. Any tips or tricks? Should I just plan on completely replacing them both? John Churchill 1980 FC33 LARGE MARGE Sanibel, FL |
03-15-2009, 10:31
I had a similar problem and got it out by removing the entire panel but the way
it finally came off, I'm not sure I'd ever get it back in. I bought one of the Progressive surge protectors w/ indicator and may put the indicator in the same place. There are SO MANY things that you nearly have to destroy to remove. Regards, GPSGary 1984FC35SB |
03-15-2009, 11:00
