removing washer/dryer
03-16-2009, 12:49
How is the w/d affixed to the slide out tray??
I am planning on removing the washer/dryer from my 91WL. It must be bolted,
locked down or just stuck to the closet slide out tray, but I do not readily see
how. Therefore, I thought it would be easier to ask the group how is it
attached and how to remove it. Thanks.
Roger Webb
91WL
Cedar Rapids, IA
03-16-2009, 13:52
Remove the screws that hold the slide-bolt at the front of the washer dryer tray
and the unit will lift our O.K.. Those screws are holding the unit down.
> Roger Webb
> 91WL
> Cedar Rapids, IA
03-17-2009, 16:17
Mine is not fastened down at all. To remove it I have to remove the 3/4" x 2"
piece of wood from the front edge of the washer and then slide out the w/d.
Eric Perplies
96 42 WBWL
currently in Gallup, NM
03-18-2009, 05:59
Perhaps... My W/D is in a closet and I had to remove it to service the dryer vent (it had become clogged). There was a board at the back of the unit covered in the ubiquitous grey felt that seemed intended to keep things from falling behind the machine. However, after considerable tugging, pulling, and prying I discovered "stealth" screws going through the board into the top of the washer. The screw heads were near invisible, as they were drawn down into the pile of the felt and it took some careful searching (by touch since I couldn't look down on the board) to find the screws. Once the screws were located and removed, it was easy to pull out the unit.
However, the installation of the W/D seems to vary by year and floorplan (and random chance)...
El Sobrante CA
"aeonix1@mac.com"
On Mar 17, 2009, at 8:17 PM, Eric Perplies wrote:
Mine is not fastened down at all. To remove it I have to remove the 3/4" x 2" piece of wood from the front edge of the washer and then slide out the w/d.
Eric Perplies
96 42 WBWL
