Genny cooling issues
05-02-2009, 15:42
Hi Gregg:
I'm glad you got your generator fan working, You said you are running 190 deg. If you have a 190 thermostat on the gen. then maybe it's cooling fine and will still run around 190 when the ambient temp. goes up.
Good Luck andI hope you enjoy your trip!
Wayne
1985 PT40
Sent: Saturday, May 2, 2009 6:51:36 PM
Subject: Re: [WanderlodgeForum] Genny cooling issues
Hi - Update on this project...
In our case the fan was wired into the breaker box on the side of the genny compartment. Someone (perhaps the shop that repaired the genny) had wired it into L1/L2, which since it's a 110V unit wasn't working. I switched the white lead to L0 and it's working fine now. There's a little more vibration than I'd like on the fan, so will be trying to adjust that. And as Wayne pointed out, one of the two blowers at the back top of the compartment was shot - the squirrel cage was shreded and detached from the motor. But the other's still working its little rodent heart out. I'll be replacing the dead one shortly. Ran the genny with all three cruise-Air units running (about 55A total load on both legs) and it peaked at a little over 190 degrees water temp after about an hour. This was with the
radiator shroud off and in the sunlight, but only 75 degree ambient temperature. We'll be in 110 degrees later this year and will need to make this work better. Hopefully the blower and the shroud replaced to improve airflow will give us the additional headroom we need. But always appreciate suggestions!
This is fun! I'm no gearhead - my college degree was in English & Philosophy. But I love learning new skills, and it is such a joy to have so much knowledge and willingness to share it available from you all!
We would make it to one of the BB rallys, but are a little afraid that we would be embarrassed by all of your beautiful rigs. We don't go for the classic polished look of a machine that just came off the showroom floor... But we are very concerned about keeping it running and functional. However, we are slowing decorating Bluefire in Burner style - adding animated elwire
on the outside and various fabrics inside, to go with the 15'x30' projection screen gear we carry on top along with our 16 foot tall Saguaro cactus.
With all this, we should be on the road east by Monday. First stop Phoenix and then on to Toast, an event on the AZ/NM border. Will post our story on our website (www.52weekburn. org) and will let you know when it's been update. It's empty right now.
Thanks again for all your help!
Greg & Barbara Young (AKA Smoke Blower and Luscious to our Burner friends)
1986 PT-40 Bluefire
About to leave home base in Escondido, CA
Each time you judge yourself you break your heart.
-Kirpal Venanji
Sent: Thursday, April 30, 2009 2:45:59 PM
Ok:
The power to the fan motor come directly from L1/L2/LO. these points are located behind the vented plate on the back side of the Kohler gen housing and are on isolated studs. Were they wired back properly? The motor can be configured as 100VAC or 220 vac, double check the way the motor is wired then check the wiring from the motor to the isolated studs. You can see those connections in your gen set manual on the 2 line wire diagram.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 02:19 PM 4/30/2009 -0700, you wrote:
Hey Ralph - Thanks for the pointer. No such switch on my control box - there are three wiring harnesses (one on the back leading to the coach and two on the tront leading to the genny), one 10A bus fuse (which is still good) and the start/stop and preheat switches. That's all.
Thanks!
Greg
86 PT-40
Escondido CA
Sent: Thursday, April 30, 2009 2:00:36 PM
Hi Greg:
Open the gen set slide and on the left side of the control box see if there
is a switch. This is not the start stop or preheat switch. Some of the
Yammar sets have a switch that cuts the cooling fan off.
Safe travels,
84FC35 "Ruff
Diamond"
Duncan, Oklahoma
At 01:51 PM 4/30/2009 -0700, you wrote:
>Hi Everybody -
>Ernie and all - Thanks on the pointers on the Chrysler power seat
>controls. Found one, and after a little plastic modification it fit and
>works perfectly. Now we can move the co-pilot's seat again!
>This one's a little more critical. Late last week we had the generator
>worked on after it completely stopped producing power - its rotor bearing
>was shot and the stator and rotor were about to start arcing due to
>insulation wear. Had them "washed, baked and dipped," and $1700 later are
>now getting plenty of power. However, it seemed to be overheating still,
>as it did on last year's long trip. We have a 1986 PT-40 with the
>side-mounted radiator and the Kohler / Yanmar12.5K generator. So I've
>pulled the radiator and noted that the fan wasn't getting any current
from
>the generator. I bypassed the feed and found that the fan blades were
>binding on the housing. I've now got the binding fixed, so it will rotate
>freely - but two things still baffle me:
>1. Is there a circuit breaker or fuse somewhere on the power feed to the
>fan that could have blown because the fan blades were stuck? Any idea of
>where to look for this?
>2. Have noted that the fan was installed so that the airflow is from
>outside to inside - pulling air through the radiator and exhausting it out
>through the cage and to the center of the coach. Is this
>normal? Functional? Flipping the fan blade doesn't help - it's got
>scooped fins and only collects air in one direction. Thoughts? The guys
>who repaired the genny suggested I get a 12V radiator fan at a local auto
>parts store, but then I'm faced with having that switch on when the
>genny's
running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
>itching to get on the road.
Safe travels,
Duncan, Oklahoma
05-02-2009, 15:57
Greg & Barbara,
Please join in any of the 'Bird rally events across the country. Your coach will fit in just fine. I would love to see what you have done with it since you bought it. I look forward to seeing you at many 'Bird rallies.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
On Sat, May 2, 2009 at 8:42 PM, Wayne Kotila <"waynekotila@yahoo.com"> wrote:
Hi Gregg:
Good Luck and I hope you enjoy your trip!
Wayne
1985 PT40
1986 PT-40 Bluefire
-Kirpal Venanji
Ok:
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
Safe travels,
84FC35 "Ruff
Diamond"
Duncan, Oklahoma
>Hi Everybody -
from
>genny's
running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
05-02-2009, 17:00
Hey Fred!  Burners are people who go to Burning Man, an event unlike any other that takes place in the Black Rock Desert NE of Reno every year the week before Labor Day. Hard to explain, but it can have a really transformational effect on some people. To others, it's a party, or the biggest gathering of avant-garde artists in the world. To some, it's evidence of all that's right with society - to still others, it proves all that's wrong. http://www.burningman.com
Greg
Sent from my iPhone
On May 2, 2009, at 8:27 PM, "Fred Bellows" <"nytexcel@yahoo.com"> wrote:
--- In WanderlodgeForum@yahoogroups.com, Greg Young wrote:
........decorating Bluefire in Burner style ............to our Burner friends)
> 1986 PT-40 Bluefire
Greg, please forgive my un-coolness, but, what's a burner?
<!--[if gte mso 9]>
Normal
0
\/\/\…Fred
__________________
Fred & Wendy Bellows
Queen Creek, AZ (so.east Phx)
'90 SP36
"Maunder Maximum"
photos of coach
and upgrades
current location
attach-count span {
color: #1E66AE;
font-weight: bold;
div#ygrp-mlmsg #ygrp-msg p a span.yshortcuts {
font-family: Verdana;
font-size: 10px;
font-weight: normal;
#ygrp-msg p a {
font-size: 10px;
#ygrp-mlmsg a {
color: #1E66AE;
div.attach-table div div a {
text-decoration: none;
div.attach-table {
width: 400px;
05-02-2009, 17:02
Thanks Curt, and Ernie too!  We will work one into our calendar!
Greg
Sent from my iPhone
On May 2, 2009, at 8:57 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
Greg & Barbara,
Curt Sprenger
Anaheim Hills, CA
Hi Gregg:
Wayne
1985 PT40
With all this, we should be on the road east by Monday.  First stop Phoenix and then on to Toast, an event on the AZ/NM border.  Will post our story on our website (http://www.52weekburn. org) and will let you know when it's been update.  It's empty right now.
1986 PT-40 Bluefire
-Kirpal Venanji
Ok:
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
Safe travels,
84FC35 "Ruff
Diamond"
Duncan, Oklahoma
>Hi Everybody -
from
>genny's
running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
.file-title a:visited {
#ygrp-msg p#attach-count {
clear: both;
padding: 15px 0 3px 0;
overflow: hidden;
#ygrp-msg p#attach-count span {
color: #1E66AE;
font-weight: bold;
font-size: 10px;
#ygrp-msg p a {
font-size: 10px;
#ygrp-mlmsg a {
color: #1E66AE;
div.attach-table {
width: 400px;
05-02-2009, 22:04
Greg,
I'm coming into this thread late. But FYI I have the 12.5 Yanmar with the Kohler
also. My fan is mounted directly on top of my radiator (which is horizontally
mounted) and blows air from the fan through the radiator to the ground. Seems to
work well!
Tom Sorrentino
1987 PT38
Bedford Hills, NY
> Hi Everybody -
> Ernie and all - Thanks on the pointers on the Chrysler power seat controls.
Found one, and after a little plastic modification it fit and works perfectly.
> This one's a little more critical. Late last week we had the generator worked
on after it completely stopped producing power - its rotor bearing was shot and
the stator and rotor were about to start arcing due to insulation wear. Had
them "washed, baked and dipped," and $1700 later are now getting plenty of
power. However, it seemed to be overheating still, as it did on last year's
long trip. We have a 1986 PT-40 with the side-mounted radiator and the Kohler /
Yanmar12.5K generator. So I've pulled the radiator and noted that the fan
wasn't getting any current from the generator. I bypassed the feed and found
that the fan blades were binding on the housing. I've now got the binding
fixed, so it will rotate freely - but two things still baffle me:
> 1. Is there a circuit breaker or fuse somewhere on the power feed to the fan
that could have blown because the fan blades were stuck? Any idea of where to
look for this?
> 2. Have noted that the fan was installed so that the airflow is from outside
to inside - pulling air through the radiator and exhausting it out through the
cage and to the center of the coach. Is this normal? Functional? Flipping the
fan blade doesn't help - it's got scooped fins and only collects air in one
direction. Thoughts? The guys who repaired the genny suggested I get a 12V
radiator fan at a local auto parts store, but then I'm faced with having that
switch on when the genny's running.
> Thanks!
> Greg Young
> 86 PT-40 Bluefire
> -Kirpal Venanji
05-18-2009, 11:43
Ralph, This is a little off the subject but do you still know where to buy the desicant cartridge 287313. I called o'reilly's auto parts but got zero.
Dan Williams,88wb38,Jackson,MS
Sent: Thursday, April 30, 2009 4:45 PM
Ok:
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
Safe travels,
Duncan, Oklahoma
>Hi Everybody -
>pulled the radiator and noted that the fan wasn't getting any current from
>genny's running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
Checked by AVG - http://www.avg.com
Version: 8.5.287 / Virus Database: 270.12.10/2088 - Release Date: 04/30/09 06:01:00
