Dinghy Odometer Reading - revisit
06-08-2005, 09:05
This past week I towed our 1990 Acura Legend down to Myrtle Beach SC
and back. I left the ignition key in position I (accessory)on way
down, odmeter still worked (443 miles), and position II(on)on way home
which also had the odometer working (446 miles). I didn't think the
Acura had a speedometer cable but maybe it does or I have to
disconnect some fuse to temporarilly disable the odometer. Any more
suggestions.
Roy Anderson
Sprinfield VA
1986 PT-40
06-08-2005, 09:20
Roy,
How was the secnic route going home?
Mark
suggestions.
Roy Anderson
Sprinfield VA
1986 PT-40
Yahoo! Groups Links
To visit your group on the web, go to:
To unsubscribe from this group, send an email to:
Discover Yahoo!
Stay in touch with email, IM, photo sharing & more. Check it out!
06-08-2005, 09:32
Drove by South of the Border, what a thrill
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mark Garber
Sent: Wednesday, June 08, 2005 5:20 PM
Subject: Re: [WanderlodgeForum] Dinghy Odometer Reading - revisit
Roy,
Mark
suggestions.
Roy Anderson
Sprinfield VA
1986 PT-40
Yahoo! Groups Links
Discover Yahoo!
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
06-08-2005, 12:11
Hi Roy,
I'm no expert but we have a friend with an Acura toad and it seems
like they had to insert the key into a slot on the shift console to
disengage the speedo. Just checked with Edythe and she said that she
puts the key in a slot on the console next to the shifter and moves
the shifter from park to neutral; Then takes the key out and puts it
in the ignition and turns it to the first click. Hers was a '92
Accord but those Hondas are all about the same. Something to check
anyway....
George
> suggestions.
> Roy Anderson
> Sprinfield VA
> 1986 PT-40
> Yahoo! Groups Links
06-08-2005, 12:30
George,
Thanks for the suggestion, I will inspect console for a key
slot. My wife's 1990 Acura was the last year for the first body style and
they made a lot of changes in 1991, hope the key slot isn't one of them.
I checked car and it does have the slot which does let me
position the ignition key in lock position without locking steering wheel,
but with a speedometer cable it might not matter. I suspect the 1991 on
Acuras have electronic speed sensors instead of a cable. Hope springs
eternal and I will give it a try when my daughter and I shove off for summer
long trip. Thanks for response. Roy
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George Lowry
Sent: Wednesday, June 08, 2005 8:12 PM
Hi Roy,
anyway....
George
> suggestions.
> Roy Anderson
> Sprinfield VA
> 1986 PT-40
> Yahoo! Groups Links
_____
Yahoo! Groups Links
