Cabinet Door Struts
05-12-2009, 08:19
Cabinet Door Struts
Which way do the struts on the interior cabinets face? The housing
up or down, or does it matter?
90WBWL401/2 Jus Chillin
05-12-2009, 08:31
Cabinet Door Struts
Steve:
All of mine have the cylinder uppermost. That is, the wide part is attached to
the door, the slender end to the cabinet frame.
--M.R.Kane
'87 PT40
currently Aledo, TX
05-12-2009, 12:59
Cabinet Door Struts
When I changed the star-wheel supports to gas struts I accidentally put most of
them in one way and a few the other way. Doesn't seem to make any difference on
our coach.
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...>
> Steve Gureasko
> Ponchatoula, La.
05-13-2009, 12:22
Cabinet Door Struts
Thats the way some of mine are Bob- they don't leak either way.
83PT40
Wanderlodge
--- On Tue, 5/12/09, freewill2008 wrote:
Subject: [WanderlodgeForum] Re: Cabinet Door Struts
Date: Tuesday, May 12, 2009, 7:59 PM
When I changed the star-wheel supports to gas struts I accidentally put most of them in one way and a few the other way. Doesn't seem to make any difference on our coach.
--- In "WanderlodgeForum%40yahoogroups.com", "patticake592000" <sgureasko@. ..> wrote:
> Steve Gureasko
> Ponchatoula, La.
05-13-2009, 17:00
Cabinet Door Struts
The fat part of the tube needs to be on the top. This keeps the fluid against the seals and keeps them lubricated and keeps the gas in the sealed part of the tub.. Mounted with the fat side down will work but you will have premature failure when they will become weak. I read this on one of the manufactures sites. Up till then I wondered the same thing
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of freewill2008
Sent: Tuesday, May 12, 2009 8:00 PM
--- In "WanderlodgeForum%40yahoogroups.com", "patticake592000" <sgureasko@.<WBR>..> wrote:
> Steve Gureasko
> Ponchatoula, La.
05-13-2009, 17:15
Cabinet Door Struts
Thanks Chuck. Guess I will turn a few of these around.
> - Chuck Wheeler-
> _____
> > Steve Gureasko
> > Ponchatoula, La.
