Aquahot leaked, How would you repair bay floor?
07-22-2009, 10:43
Rich,
No nothing as nice as that. If it had a non permeable medium under it I would
not have to replace the Ozite. The Ozite carpet is still under the Aquahot, I
cut around the perimeter of the Aquahot and removed everything from it up to the
Joey bed on the curb side. It's not the fix I would like to do but I've spent
more time working on her than I have playing with her so on this one a quick fix
is in order. Besides this is the bay that gets all the hoses and electric lines
stored in it and half the time their either wet or dirty or both so I'm not real
keen on making it pretty just practical. Besides I'm startin the repair on the
A/C compressor bracket on the
S-60 tomorrow so times a wastin! LOL
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote:
> Kurt,
> Did the carpet go under the AquaHot or just around it? On my '99 they didn't
use carpet in that bay but went with a thick, black vinyl tile/linoleum. They
did the same in the bay forward of that with the waterpumps, filter, etc. and to
the rear in the water hookup bay. All others have the carpet.
> Rich D. '99LXi43' CT
> --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" wrote:
> > Hi guys,
> > I got the old OZITE Carpet out of the bay today. Fortunately the fluids did
not creep up the side walls and what didn't come out I'll just have to live
with. I'm not going to take the Aquahot out until I have to. Too much trouble
for whatever advantage will be gained.
> > I'll say one thing this stuff is tough. The glue backing of course has been
turned to slime but the carpet itself is still very much intact. It would not
tear at all; I had to cut it out. A little elbow grease and some Acetone and the
slimed glue is off the sheet metal floor and is ready for a new covering, I'll
get over to Home Depot and by some more Ozite in the morning,
> > "Kurt, I believe underneath your carpet is metal. The carpet used is Ozite
unitary backed. You will have to scrape it off. Home Depot, actually, has this
material in stock. Ernie Ekberg", exactly as described Ernie, thanks!
> > Some paint did come off with the cleaning operation and there is some
minimal rusting, just some coin sized spots, I'll clean those up and shoot some
paint on the bare sports before installing the new Ozite.
> > Thanks for all the suggestions.
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > --- In WanderlodgeForum@yahoogroups.com, "martingregg598"
> > > Kurt, a year or two ago I made a holder for my chair's in the storage
compartments and wanted it to look the same so I called Holland Motors in
Michigan and they had a piece of that gray stuff, I would call around to some of
the old BB dealers and you might find the right stuff. Also when my A/H leaked
I had to pull all the sheet metal and replace the duct liner insulation around
the tank, it was soaked with diesel too.
> > > Marty Gregg
> > > 95 BMC 37
> > > Kennewick WA
07-23-2009, 02:12
Kurt,
Before replacing the carpet go to your local heating oil supplier or plumbing
supply shop and get a 16 oz container of OdorOut, the powder heating oil
companies use on minor oil spills in homes. Since you can't get the carpet out
from under the AquaHot, dissolve some powder in water and soak the carpet. When
dry (pretty quickly if using the AquaHot) most of the odor will be gone. Repeat
if necessary. OdorOut is usually available at heating/plumbing wholesalers for
about $6.00 - $8.00.
> Rich,
> Kurt Horvath
> 95 PT 42
> 10AC
> > Kurt,
> > > Hi guys,
did not creep up the side walls and what didn't come out I'll just have to live
been turned to slime but the carpet itself is still very much intact. It would
not tear at all; I had to cut it out. A little elbow grease and some Acetone and
the slimed glue is off the sheet metal floor and is ready for a new covering,
I'll get over to Home Depot and by some more Ozite in the morning,
> > > Kurt Horvath
> > > 95 PT 42
> > > 10AC
> > > > Marty Gregg
> > > > 95 BMC 37
> > > > Kennewick WA
