Air Leaks
08-29-2009, 13:14
Air Leaks
Hi Guys
I was chasing down some small air leaks & found some in my push on plastic
fittings & a pipe fitting at my steps. I found a 1/4" copper tube dropping down
in front of my battery box front street side. It is not connected to any thing &
there is nothing there to connect it to. It is leaking enough air that it drains
my auxiliary tank over night. Does any one know where this tube go's to? I
though it went to my park brake to release the air but when I released the brake
the air didn't exit there.
Don Spithaler
89 SP 36'
Butler, PA
08-29-2009, 16:31
Air Leaks
maybe it is an exhaust and the ram it exhaust or the valve is leaking. if you
plug it up the steps may not retract?????? that may narrow your search
Greg of Tim&Greg
94ptca
--- In WanderlodgeForum@yahoogroups.com, "dspithaler" wrote:
> Hi Guys
> Don Spithaler
> 89 SP 36'
> Butler, PA
08-30-2009, 00:49
Air Leaks
The front air conditioner condensation tube on my rig comes out near the same location. Maybe???
jco2
Sent: Saturday, August 29, 2009 11:31 PM
Subject: [WanderlodgeForum] Re: Air Leaks
maybe it is an exhaust and the ram it exhaust or the valve is leaking. if you plug it up the steps may not retract?????? that may narrow your search
Greg of Tim&Greg
94ptca
--- In "WanderlodgeForum@yahoogroups.com", "dspithaler" ...> wrote:
> Hi Guys
> I was chasing down some small air leaks & found some in my push on plastic fittings & a pipe fitting at my steps. I found a 1/4" copper tube dropping down in front of my battery box front street side. It is not connected to any thing & there is nothing there to connect it to. It is leaking enough air that it drains my auxiliary tank over night. Does any one know where this tube go's to? I though it went to my park brake to release the air but when I released the brake the air didn't exit there.
> Don Spithaler
> 89 SP 36'
> Butler, PA
08-30-2009, 12:12
Air Leaks
I plugged it up with a fitting & everything is working. My park brake works & my service brakes work. I just can't find where it goes to.
Don Spitrhaler
89 SP 36'
Butler, PA
    jco2
Greg of Tim&Greg
94ptca
--- In "WanderlodgeForum@yahoogroups.com", "dspithaler" wrote:
> Hi Guys
> Don Spithaler
> 89 SP 36'
> Butler, PA
