A long afternoon
02-27-2010, 16:27
A long afternoon
I spent all afternoon (into the early evening) opening up the bed and then the
innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? Long day..... having fun. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
02-28-2010, 06:43
A long afternoon
It's your hobby Mike, and sure beats sitting in front of the tube all day! And
when you finish a job there is nothing like the gratification and higher level of confidence you now have in your coach. Good job! Robert Britton Hollister, California |
02-28-2010, 07:32
A long afternoon
Hi Mike
I replaced the #1 Alt. twice on my 93. After the second time It failed again and I just took it off and left it off. I never had any problem's with the # 2 and it charged everything just fine. Talking to BB sometime later I was told that the cable's were too small and they thought that was the problem with premature failure of #1?????? Bob 99LX SK..SPI till 20Mar. --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > Long day..... having fun. > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
02-28-2010, 07:58
A long afternoon
Mike: Why do you want to change thermostats to 170's? Good heat without
overheat makes the engine run better and more efficiently. I think 180's is cool enough. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > Long day..... having fun. > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
02-28-2010, 08:06
A long afternoon
Mike, I've been told the long coolant hose to my 8V92's air compressor runs too close to the hot manifold to allow using a stainless steel hose.
Rick Davis
1993 WBSA
Loudon, TN
From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Sat, February 27, 2010 11:27:55 PM Subject: [WanderlodgeForum] A long afternoon I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? Long day..... having fun. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX |
02-28-2010, 08:40
A long afternoon
Rick,
Hi.. We're new to the forum and BB.. We have a 93WLWB. We're wondering if you've had any issues with your shower faucets? My husband Ted would like to talk to you if possible. Could you PM us or private email with a number where we could reach you. TIA Sally and Ted Brustowicz 1993 WLWB PT Niceville Fl 32578 "TrBrustowicz@cox.net"
On Feb 28, 2010, at 2:06 PM, Rick Davis wrote:
02-28-2010, 08:45
A long afternoon
I sent you a PM.
Rick Davis
1993 WBSA
Loudon, TN
865-789-3130
"davisgr2@yahoo.com"
From: sally brustowicz <sbrustowicz@...> To: WanderlodgeForum@yahoogroups.com Sent: Sun, February 28, 2010 3:40:12 PM Subject: Re: [WanderlodgeForum] A long afternoon Rick, Hi.. We're new to the forum and BB.. We have a 93WLWB.
TIA
1993 WLWB PT
Niceville Fl 32578
"TrBrustowicz@cox.net" On Feb 28, 2010, at 2:06 PM, Rick Davis wrote:
02-28-2010, 09:46
A long afternoon
I dropped my thermostststo 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig.
From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Sun, February 28, 2010 1:58:50 PM Subject: [WanderlodgeForum] Re: A long afternoon Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In "WanderlodgeForum%40yahoogroups.com", "mbulriss" <mbulriss@.. .> wrote: > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > Long day..... having fun. > > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
02-28-2010, 14:20
A long afternoon
Thanks Rick. I'll take another look, but it appears to be at least 6" below the
rear of the exhaust manifold on mine. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Rick Davis > > Mike, I've been told the long coolant hose to my 8V92's air compressor runs too close to the hot manifold to allow using a stainless steel hose.Ã > > Rick Davis > 1993 WBSA > Loudon, TN > > > > > ________________________________ > From: mbulriss <mbulriss@...> > To: WanderlodgeForum@yahoogroups.com > Sent: Sat, February 27, 2010 11:27:55 PM > Subject: [WanderlodgeForum] A long afternoon > > Ã > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > Long day..... having fun. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
02-28-2010, 14:49
A long afternoon
Well Ron, IMO I think a slightly cooler temp promotes engine longevity. Rick
Archie and Leroy Eckert reported good results going with lower temp thermostats. Maybe they will pop in here to articulate further on their results. In my case, when I am not running the A/C the temp constantly rises to 195 and then drops to 180 when the t-stats open and then it constantly repeats the cycle. If (and since) I run the A/C constantly, it puts the fan in override and running all the time and keeps the temp at 180, where I am more comfortable. From my years on the forum, I have learned that the 6V/8V Detroits do not tolerate temps much over 200 very well. My feeling is that 195 does not give me much comfort room if a t-stat sticks, or a water hose breaks. Bluebird over-engineered the dashboard, but the two most important IMO are still oil pressure and water temp. While I watch both of those pretty carefully, I do not like having to drive with one eye on the temp gauge constantly. Since I mainly drive in a relatively very warm area of the country (the last two months notwithstanding) 170 seems to give a bigger margin of safety and I find it hard to believe that the Detroit will react badly to a 10 degree lower water jacket temp. Now I admit that I am assuming that the 170 t-stats will rise to 180+ before they cycle back down to 170 and close, thereby cycling like my current t-stats. If it sounds like my current t-stats are just worn out, and cycling too high, let me know. Anyway, that's why 170 t-stats are on my to-do list. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
