Source for replacement upholstery
06-03-2010, 02:08
Recently I had to replace a padded vinyl covered ceiling panel due to water
damage from a leaking skylight. I contacted several sources but only one
responded, Gary's Upholstery in Tampa, FL. They provided fast service and were
pleasant to work with. They will request a small sample for matching and will
send 2 or 3 samples for you to choose from. In my case they came up with a
perfect match. Contact them at http://www.garysupholstery.com if you need to match or
replace upholstery material.
Royal Washburn
97BBWL43'
Conway, AR
06-03-2010, 02:27
Royal
Thanks for the information.
I was thinking about that very issue a couple days ago .
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
06-03-2010, 11:44
> Royal Washburn
> 97BBWL43'
> Conway, AR
Did you try Murial's in Ft. Valley, Ga?
Bob Lawrence
84 PT36
Flanders, NJ
07-24-2010, 11:09
--- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob"
> > Royal Washburn
> > 97BBWL43'
> > Conway, AR
> Bob Lawrence
> 84 PT36
> Flanders, NJ
I'm a newbie to the group and do not have a coach but the ones I am considering
all have headliner sagging.
First of all, how does one take it off, and will removal damage it, or other
stuff to get at it?
07-27-2010, 00:01
First, please sign your posts and indicate the year and type of Bluebird you are interested in. If you did this in a prior post, I must have missed it.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sat, 7/24/10, wbostow wrote:
Subject: [WanderlodgeForum] Re: Source for replacement upholstery
Date: Saturday, July 24, 2010, 6:09 PM
> > Recently I had to replace a padded vinyl covered ceiling panel due to water damage from a leaking skylight. I contacted several sources but only one responded, Gary's Upholstery in Tampa, FL. They provided fast service and were pleasant to work with. They will request a small sample for matching and will send 2 or 3 samples for you to choose from. In my case they came up with a
perfect match. Contact them at http://www.garysupholstery.com if you need to match or replace upholstery material.
> > Royal Washburn
> > 97BBWL43'
> > Conway, AR
> Bob Lawrence
> 84 PT36
> Flanders, NJ
I'm a newbie to the group and do not have a coach but the ones I am considering all have headliner sagging.
First of all, how does one take it off, and will removal damage it, or other stuff to get at it?
