Fire Hazard
06-25-2010, 01:59
Fire Hazard
After removing a fresh water tank on an SP, we found that the freeze protection
mat had scorched the bottom of the tank and the plywood floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that has this setup should absolutely discontinue using it. I will post a few photos in the photo section and will title it fire hazard. Ernie-83PT40 in Texas |
06-25-2010, 02:08
Fire Hazard
Ernie
That tank is in the bathroom closet,right?
They are a plastic tank and most owners have had to replace or repair that tank.
The 91 SP 36 I owned had been replaced with a stainless steel tank.
I can now see one reason why so many of those tanks required repair or replacement.
Fred & Jeanne Hulse
06-25-2010, 02:18
Fire Hazard
06-25-2010, 02:40
Fire Hazard
Probably one helpful solution if the tanks are still holding water,is to find the power source for that heat pad and remove it and any trace of it!!
Fred & Jeanne Hulse
06-25-2010, 03:04
Fire Hazard
06-25-2010, 03:27
Fire Hazard
Where is the Blue Bird Museum?
Rick Archie's nursery building?
Or the Quartzsite fire pit?
Fred & Jeanne Hulse
06-25-2010, 04:22
Fire Hazard
07-01-2010, 09:07
Fire Hazard
Ernie, Are heaters used with the 84pt40? Ken Doyle ConServe 100 Pine View Dr Mobjack, VA 23056 h: 804-725-3132 f: 804-725-2982 c: 301-908-5735 From: After removing a fresh water tank on an SP, we found that the freeze protection mat had scorched the bottom of the tank and the plywood floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that has this setup should absolutely discontinue using it. I will post a few photos in the photo section and will title it fire hazard. Ernie-83PT40 in Texas |
07-01-2010, 09:12
Fire Hazard
Ken,
We had those vertical electric heaters on our '84 FC. Brad (former LXi) "bbartonwx@hotmail.com" http://www.bradsweather.com To: WanderlodgeForum@yahoogroups.com From: ken.hvac-conserve@... Date: Thu, 1 Jul 2010 17:07:26 -0400 Subject: RE: [WanderlodgeForum] Fire Hazard Ernie,
Ernie-83PT40 in Texas The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started. |
07-01-2010, 09:15
Fire Hazard
Ken, not the fresh water tank in your Coach. You have a small space heater attached to a gray square D thermostat control
Safe travels, Ralph Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T From: "Ken Doyle" Date: Thu, 1 Jul 2010 17:07:26 -0400 To: Subject: RE: [WanderlodgeForum] Fire Hazard Ernie, Are heaters used with the 84pt40? Ken Doyle ConServe 100 Pine View Dr Mobjack, VA 23056 h: 804-725-3132 f: 804-725-2982 c: 301-908-5735 From: After removing a fresh water tank on an SP, we found that the freeze protection mat had scorched the bottom of the tank and the plywood floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that has this setup should absolutely discontinue using it. I will post a few photos in the photo section and will title it fire hazard. Ernie-83PT40 in Texas |
