AC power lost on one leg
07-29-2010, 11:49
While running the generator to charge batteries one of the legs quit. I was
running both front and rear air at the time. The inverter and rear
air are on the same circuit. That is the circuit that quit. The over-
head panel AC voltmeters both read 120v. On the monitor panel in the
kitchen one meter read zero and the other read 120v.
Any ideas out there?
Art Weatherly
Riverside Ca
85 PT36
07-29-2010, 12:34
Art
Check the circuit breakers at your panel and also you may have circuit brkrs at the genset.
Fred Hulse
97BB41
07-30-2010, 11:27
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Art
at the genset.
> Fred Hulse
> 97BB41
Ckt breakers cheched OK.
Today I took the cover off the AC breaker panel.
I disc. the two inputs to the panel and swapped them. Started the genset
and had power to both legs. I ran it for about 20 minutes. Nothing abnormal. I
am curious as to why the main voltmeters both about 130v.
Is that in range?
Art Weatherly
Riverside Ca
'85 PT36
07-30-2010, 12:17
My generator is different than yours (a "Universal" only used in 1990, I think),
that runs at 130v no-load at 60Hz. If I set its speed down at all the voltage
will drop, but so will the Hz. Under significant load it drops to around 128v.
I've not experienced any problems except I had to set the max level for my
inverter (ProSine 2.0) to 131 or it won't kick out of inversion mode.
Don Bradner
90 PT40 "Blue Thunder"
>> Art
>> Fred Hulse
>> 97BB41
>abnormal. I am curious as to why the main voltmeters both about 130v.
>Is that in range?
>Art Weatherly
>Riverside Ca
>'85 PT36
07-30-2010, 23:38
Use a real voltmeter and do not trust the panel mount units. If you really have 130 volts you have other issues that will cause damage to the rest of your things.
gary 85pt40
--- On Fri, 7/30/10, Don Bradner wrote:
Subject: Re: [WanderlodgeForum] Re: AC power lost on one leg
Date: Friday, July 30, 2010, 8:17 PM
My generator is different than yours (a "Universal" only used in 1990, I think), that runs at 130v no-load at 60Hz. If I set its speed down at all the voltage will drop, but so will the Hz. Under significant load it drops to around 128v.
I've not experienced any problems except I had to set the max level for my inverter (ProSine 2.0) to 131 or it won't kick out of inversion mode.
Don Bradner
>> Art
>> Fred Hulse
>> 97BB41
>Is that in range?
>Art Weatherly
>Riverside Ca
>'85 PT36
07-31-2010, 04:55
Gary, I'm reading the 130 off the digital display for the ProSine. I have tons
of expensive electronics (besides normal Blue Bird stuff) in my bus (others here
can attest!) and have never had a problem.
>gary 85pt40
>From: Don Bradner
>Â
>Don Bradner
>>> Art
>>> Fred Hulse
>>> 97BB41
>>Is that in range?
>>Art Weatherly
>>Riverside Ca
>>'85 PT36
07-31-2010, 05:08
Yes I can attest to the fact that Don has "tons of expensive" stuff in his rig droooool. And yes he doesn't let the smoke get out of the box. He does however deplete my wallet on an annual basis (usually during and right after Quartzsite). His recommendations are killing me VBG
On 31 July 2010 09:55, Don Bradner <"bluethunder@arcatapet.com"> wrote:
Gary, I'm reading the 130 off the digital display for the ProSine. I have tons of expensive electronics (besides normal Blue Bird stuff) in my bus (others here can attest!) and have never had a problem.
>gary 85pt40
>--- On Fri, 7/30/10, Don Bradner <"bluethunder@arcatapet.com"> wrote:
>From: Don Bradner <"bluethunder@arcatapet.com">
>To: "WanderlodgeForum@yahoogroups.com"
>Don Bradner
>My location: www.bbirdmaps.com/user2.cfm?user=1
>>--- In "WanderlodgeForum@yahoogroups.com", "Fred Hulse" wrote:
>>> Art
>>> Fred Hulse
>>> 97BB41
>>Is that in range?
>>Art Weatherly
>>Riverside Ca
>>'85 PT36
Yahoo! Groups Links
<*> Your email settings:
   (Yahoo! ID required)
Rob, Sue and Joey Robinson
07-31-2010, 06:08
Give up now! You will never catch up...
>after
07-31-2010, 06:41
Okay Dad, where do I send the cheque???
>after
07-31-2010, 08:33
I was in Don's coach at Quartzite. He has 4 air conditioners going to keep all that electronic "stuff" cool. I haven't a clue what all those things are with all those lites. İmage
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
Date: Saturday, July 31, 2010, 11:55 AM
>gary 85pt40
>--- On Fri, 7/30/10, Don Bradner <bluethunder@...> wrote:
>From: Don Bradner <bluethunder@...>
leg
>Don
Bradner
>>> Art
>>> Fred Hulse
>>> 97BB41
>>and had
>>Is that in range?
>>Art Weatherly
>>Riverside Ca
>>'85 PT36
Yahoo! Groups Links
email:
User(s) browsing this thread: 6 Guest(s)
