AC one leg
08-09-2010, 11:12
AC one leg
Shane,
Good to hear from you. The inverter does work from batteries to AC. Futher more, I reconnected the inverter inut AC leg back to the breaker panel (with the inverter AC output still disc.). In that configuration the generator AC leg was not dropped. This gets curiouser and curiouser. I am taking a battery charger with me. Will plug it in when the generator is running. My inverter is located in the middle small closet behind the bed - doesn't get wet or dirty, but I have to remember to leave the closet door open for cooling. Art Weatherly Riverside Ca '85 PT36 |
08-10-2010, 00:26
AC one leg
Hi Art,
It sounds to me like you "could" have a welded transfer relay. This can happen when an A/C compressor tries to start while in the invert mode. Are any of your A/C's powered through the inverter? -Shane --- In WanderlodgeForum@yahoogroups.com, "artw" > > Shane, > > Good to hear from you. > > The inverter does work from batteries to AC. Futher more, I reconnected > the inverter inut AC leg back to the breaker panel (with the inverter > AC output still disc.). In that configuration the generator AC leg was not dropped. This gets curiouser and curiouser. I am taking a battery > charger with me. Will plug it in when the generator is running. > > My inverter is located in the middle small closet behind the bed - > doesn't get wet or dirty, but I have to remember to leave the closet > door open for cooling. > > > Art Weatherly > Riverside Ca > '85 PT36 > |
08-10-2010, 03:33
AC one leg
My inverter AC output is conn. to one of the two main breakers, so
it supplies power to 1/2 of the AC panel. That would include one of the air conditioners. It took me some time to figure that out as it follows none of the examples in the manuals on how to hook it up. Of course there were no examples availible as to how it was connected. Leave tomorrow for Monterey. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hi Art, > > It sounds to me like you "could" have a welded transfer relay. This can happen when an A/C compressor tries to start while in the invert mode. Are any of your A/C's powered through the inverter? > > -Shane > > --- In WanderlodgeForum@yahoogroups.com, "artw" > > > > Shane, > > > > Good to hear from you. > > > > The inverter does work from batteries to AC. Futher more, I reconnected > > the inverter inut AC leg back to the breaker panel (with the inverter > > AC output still disc.). In that configuration the generator AC leg was not dropped. This gets curiouser and curiouser. I am taking a battery > > charger with me. Will plug it in when the generator is running. > > > > My inverter is located in the middle small closet behind the bed - > > doesn't get wet or dirty, but I have to remember to leave the closet > > door open for cooling. > > > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > |
