Led Tank and clock displays
09-28-2010, 04:54
I have a 1988 wbwl walk thriugh bath. in the overhead cabinet next to the
refrigerator is a panel that contains controls for genny odor controls. both leds have gone bad. i am looking for replacements Any Ideas? |
09-28-2010, 08:53
09-28-2010, 09:23
he is looking for numerical readouts not leds
Stephen 97bmc 37 --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > If you have electical knowledge and are comfortable working with it, you can buy L E Ds at Radio schack and solder new ones on the circuite board. If they are not on a board and are connected with wires thats easier yet. Radio schack has a variety of L E Ds in a variety of colors and a couple sizes (5mm or 10mm). Some are in mounting rings that allowà them to snap into a mounting hole in a panel and these are usually set up already for a certain voltage like 12 volt. If you buy justà the L E D by itself, you will have toà solder a resistor to theà positive wire from the L Eà D becauseà the L E D only usesà between 3 and 4 volts, usually for 12 volt a 1000 ohm resistor is what is needed. L E Ds are positive/negative specific,à and if you are adding a resistor, solder it to the positveà wire from the L Eà D. If you reverse the polarityà it doesn't damage the L E D, ità just won't light. > I hope this helps > à > Wayne kotila > 96PT42à à > > --- On Tue, 9/28/10, jr > > > From: jr > Subject: [WanderlodgeForum] Led Tank and clock displays > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, September 28, 2010, 4:54 PM > > > à > > > > I have a 1988 wbwl walk thriugh bath. in the overhead cabinet next to the refrigerator is a panel that contains controls for genny odor controls. both leds have gone bad. i am looking for replacements Any Ideas? > |
09-28-2010, 09:23
09-28-2010, 09:39
You can purchase numerical readouts from: http://www.digikey.com/
They sell almost any electronic component you could wish for. Radio shack doesn't havemany componentsany more.
Bill
Michigan
09-28-2010, 23:41
i looked at digikey ,mouser,future electronics,and allied there was nothing
suitable Stephen 97 BMC37 --- In WanderlodgeForum@yahoogroups.com, "Bill Prestin" > > You can purchase numerical readouts from: http://www.digikey.com/ > > They sell almost any electronic component you could wish for. Radio shack doesn't have many components any more. > > Bill > Michigan > > ----- Original Message ----- > From: cape0001 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, September 28, 2010 5:23 PM > Subject: [WanderlodgeForum] Re: Led Tank and clock displays > > > > he is looking for numerical readouts not leds > Stephen 97bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > > > If you have electical knowledge and are comfortable working with it, you can buy L E Ds at Radio schack and solder new ones on the circuite board. If they are not on a board and are connected with wires thats easier yet. Radio schack has a variety of L E Ds in a variety of colors and a couple sizes (5mm or 10mm). Some are in mounting rings that allowà them to snap into a mounting hole in a panel and these are usually set up already for a certain voltage like 12 volt. If you buy justà the L E D by itself, you will have toà solder a resistor to theà positive wire from the L Eà D becauseà the L E D only usesà between 3 and 4 volts, usually for 12 volt a 1000 ohm resistor is what is needed. L E Ds are positive/negative specific,à and if you are adding a resistor, solder it to the positveà wire from the L Eà D. If you reverse the polarityà it doesn't damage the L E D, ità just won't light. > > I hope this helps > > à > > Wayne kotila > > 96PT42à à > > > > --- On Tue, 9/28/10, jr > > > > > > From: jr > > Subject: [WanderlodgeForum] Led Tank and clock displays > > To: WanderlodgeForum@yahoogroups.com > > Date: Tuesday, September 28, 2010, 4:54 PM > > > > > > à > > > > > > > > I have a 1988 wbwl walk thriugh bath. in the overhead cabinet next to the refrigerator is a panel that contains controls for genny odor controls. both leds have gone bad. i am looking for replacements Any Ideas? > > > |
