FYI - 3208 Lube Oil Leak Problem Solved
11-07-2010, 11:02
Few days back I was looking for info on source of lube oil leak I had on top of
our 3208. After checking on my own and replacing the lube oil hose to the air compressor, the leak was still going. Finally decided to turn it over to a real diesel mechanic. Turned out the lube leak was coming from a bad O ring where the fuel injection pump shaft is inserted into the block. Mechanic had to open up the front end to remove the fuel injection pump. Big job - beyond my capabilities! Regards, Eric 84FC35SBWL2 |
11-07-2010, 12:23
Eric
Happy you found your leak,sorry it was a big job to repair.
Some things are like that,but at least it's fixed.
Fred & Jeanne Hulse
Morristown,Arizona 97 WLWB41 |
11-07-2010, 12:56
Eric,
For future reference on my part, which diesel mechanic did you use? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "bberic35" > > Few days back I was looking for info on source of lube oil leak I had on top of our 3208. After checking on my own and replacing the lube oil hose to the air compressor, the leak was still going. Finally decided to turn it over to a real diesel mechanic. Turned out the lube leak was coming from a bad O ring where the fuel injection pump shaft is inserted into the block. Mechanic had to open up the front end to remove the fuel injection pump. Big job - beyond my capabilities! > > Regards, Eric > 84FC35SBWL2 > |
11-07-2010, 14:40
Mike,
Work was done at Seguin DIesel. Clyde Schumman and his boys are top notch in my book. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Eric, > > For future reference on my part, which diesel mechanic did you use? > > Thanks, > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "bberic35" > > > > Few days back I was looking for info on source of lube oil leak I had on top of our 3208. After checking on my own and replacing the lube oil hose to the air compressor, the leak was still going. Finally decided to turn it over to a real diesel mechanic. Turned out the lube leak was coming from a bad O ring where the fuel injection pump shaft is inserted into the block. Mechanic had to open up the front end to remove the fuel injection pump. Big job - beyond my capabilities! > > > > Regards, Eric > > 84FC35SBWL2 > > > |
11-07-2010, 14:56
They will be servicing mine tomorrow morning!
Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 11/8/2010 at 2:40 AM bberic35 wrote: >Mike, >Work was done at Seguin DIesel. Clyde Schumman and his boys are top notch >in my book. >Regards, Eric >84FC35SBWL2 > >--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: >> >> Eric, >> >> For future reference on my part, which diesel mechanic did you use? >> >> Thanks, >> >> Mike Bulriss >> 1991 WB40 "Texas Minivan" >> San Antonio, TX >> >> --- In WanderlodgeForum@yahoogroups.com, "bberic35" >> > >> > Few days back I was looking for info on source of lube oil leak I had >on top of our 3208. After checking on my own and replacing the lube oil >hose to the air compressor, the leak was still going. Finally decided to >turn it over to a real diesel mechanic. Turned out the lube leak was >coming from a bad O ring where the fuel injection pump shaft is inserted >into the block. Mechanic had to open up the front end to remove the fuel >injection pump. Big job - beyond my capabilities! >> > >> > Regards, Eric >> > 84FC35SBWL2 >> > >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
