SP-36 Engine Light
11-07-2010, 11:30
SP-36 Engine Light
Our SP-36 has 79,000 miles and the check engine light comes on. There appears to
be nothing wrong with the engine. All gauges are normal and fluids full. The
wiring diagram is not clear where the fault sender(s) are located. Does anyone
have suggestions?
Paul Cunningham
1990 SP-36
Virginia
11-07-2010, 12:45
SP-36 Engine Light
Paul   My light comes on also. It usually goes out after I start driving. My sender is at the top radiator hose. I replaced mine once so I don't know what is causing my light to come on. It should be telling you that your coolant  is  low. At least that is what I think.
Don Spithaler
89 SP-36
Butler, PA
On Sun, Nov 7, 2010 at 6:30 PM, bluebirdsp36 <"bluebirdsp36@yahoo.com"> wrote:
Our SP-36 has 79,000 miles and the check engine light comes on. There appears to be nothing wrong with the engine. All gauges are normal and fluids full. The wiring diagram is not clear where the fault sender(s) are located. Does anyone have suggestions?
Paul Cunningham
1990 SP-36
Virginia
11-07-2010, 12:55
SP-36 Engine Light
That same check engine light will go off with early or late timing as well and if an injector is sticking. The ABS system can send a msg too. Though the low coolant is the usual. Some times cleaning the DDEC connectors will help too along with the ECU.
Just some other thoughts on it. Need to have a reader put on the alarm to know for sure.
Safe travels, Ralph Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
Date: Sun, 7 Nov 2010 19:45:33 -0500
To:
Subject: Re: [WanderlodgeForum] SP-36 Engine Light
Don Spithaler
89 SP-36
Butler, PA
Paul Cunningham
1990 SP-36
Virginia
11-07-2010, 13:06
SP-36 Engine Light
No DDEC on an SP36, but the first question that came to my mind was "isn't there
any code that can be flashed like on the DDEC?"
Don Bradner
90 PT40 "Blue Thunder"
>know for sure.
>Safe travels, Ralph &
>Duncan, Oklahoma
>-----Original Message-----
>From: Donald Spithaler
>Sender: WanderlodgeForum@yahoogroups.com
>To:
>My
>Don Spithaler
>89 SP-36
>Butler, PA
>are
>> Paul Cunningham
>> 1990 SP-36
>> Virginia
11-07-2010, 13:32
SP-36 Engine Light
--- In WanderlodgeForum@yahoogroups.com, "bluebirdsp36"
have suggestions?
> Paul Cunningham
> 1990 SP-36
> Virginia
Paul,
No check engine light in an SP as you have in an electronic controlled engine.
The engine alarm light will indicate low coolant level, high coolant temperature
and low oil pressure (and maybe others - I will try to check whatever else).
Coolant level is the most likely cause if the temp and pressre are OK on your
gages.
Jim Brookshire
1989 SP-36
Saluda, NC
11-07-2010, 13:33
SP-36 Engine Light
have suggestions?
> Paul Cunningham
> 1990 SP-36
> Virginia
Paul,
gages.
Jim Brookshire
1989 SP-36
Saluda, NC
11-07-2010, 13:47
SP-36 Engine Light
a 90-sp has ABS????????
Stephen 97bmc37
along with the ECU.
for sure.
> Duncan, Oklahoma
> To:
> Don Spithaler
> 89 SP-36
> Butler, PA
> > Paul Cunningham
> > 1990 SP-36
> > Virginia
11-07-2010, 13:52
SP-36 Engine Light
My bad, everyone. I read 89 and 90 and the minds eye did not read SP. That and
football is on, no Steve, not the round football, the real one! Grin
Duncan, Oklahoma
Date: Mon, 08 Nov 2010 01:47:51
To:
Subject: [WanderlodgeForum] Re: SP-36 Engine Light
Stephen 97bmc37
along with the ECU.
for sure.
> Duncan, Oklahoma
> To:
> Don Spithaler
> 89 SP-36
> Butler, PA
> > Paul Cunningham
> > 1990 SP-36
> > Virginia
Yahoo! Groups Links
