OUR 1993 BB IS SICK !!! HELP!!
11-17-2010, 01:54
Howdy.
<b style="color: rgb(0, 0, 153);">Right now we are at the East Fork COE park at Lake Lavon, near Wylie, TX. We are having real problems with the Bird. The Check Engine light and the Test Engine lights come on and a buzzer buzzes. The engine loses power, kinda stumbles for about 4 seconds. Then it recovers and goes on as normal. We thought that this was caused by the coolant level sensor which was dying. Jack replaced that sensor but it didn't solve this problem. One other thing is the tach. The tach needle will wander then settle down, then wander again. We want to get the coach down to Clyde in Seguin, TX, BUT I am really worried that we might get stranded on the side of a road. Suggestions, ideas for a solution would be most welcomed. Jack and Liz Pearce 1993 BB WLWB Currently in Wylie, TX [/b] |
11-17-2010, 03:28
Smells like electrical to me. Usually - Chuck 1982 FC 31SB From: Howdy. Right now we are at the East Fork COE park at near We are having real problems with the Bird. The Check Engine light and the Test Engine lights come on and a buzzer buzzes. The engine loses power, kinda stumbles for about 4 seconds. Then it recovers and goes on as normal. We thought that this was caused by the coolant level sensor which was dying. Jack replaced that sensor but it didn't solve this problem. One other thing is the tach. The tach needle will wander then settle down, then wander again. We want to get the coach down to Clyde in we might get stranded on the side of a road. Suggestions, ideas for a solution would be most welcomed. Jack and Liz Pearce 1993 BB WLWB Currently in |
11-17-2010, 03:46
Check the codes on the engine - hold down the engine test button, and count the
flashes, which will be in sets of two. There may be several codes, hold it down until it repeats and record all codes. Tell us what you get. On 11/17/2010 at 1:54 PM txfulltimers wrote: >Howdy. >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, >TX. > >We are having real problems with the Bird. The Check Engine light and >the Test Engine lights come on and a buzzer buzzes. The engine loses >power, kinda stumbles for about 4 seconds. Then it recovers and goes on >as normal. We thought that this was caused by the coolant level sensor >which was dying. Jack replaced that sensor but it didn't solve this >problem. One other thing is the tach. The tach needle will wander then >settle down, then wander again. We want to get the coach down to Clyde >in Seguin, TX, BUT I am really worried that we might get stranded on the >side of a road. Suggestions, ideas for a solution would be most >welcomed. > >Jack and Liz Pearce >1993 BB WLWB >Currently in Wylie, TX |
11-17-2010, 04:09
Jack, did ya'll by chance touch the rear start switch? I got both engine and trans Check lights when I did that.
Bob J.
From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Wed, November 17, 2010 9:46:06 AM Subject: Re: [WanderlodgeForum] OUR 1993 BB IS SICK !!! HELP!! Check the codes on the engine - hold down the engine test button, and count the flashes, which will be in sets of two. There may be several codes, hold it down until it repeats and record all codes. Tell us what you get. On 11/17/2010 at 1:54 PM txfulltimers wrote: >Howdy. >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, >TX. > >We are having real problems with the Bird. The Check Engine light and >the Test Engine lights come on and a buzzer buzzes. The engine loses >power, kinda stumbles for about 4 seconds. Then it recovers and goes on >as normal. We thought that this was caused by the coolant level sensor >which was dying. Jack replaced that sensor but it didn't solve this >problem. One other thing is the tach. The tach needle will wander then >settle down, then wander again. We want to get the coach down to Clyde >in Seguin, TX, BUT I am really worried that we might get stranded on the >side of a road. Suggestions, ideas for a solution would be most >welcomed. > >Jack and Liz Pearce >1993 BB WLWB >Currently in Wylie, TX |
11-17-2010, 07:25
Hi Jack & Liz,
Call your mechanic and ask him if he knows a reputable Mobile Mechanic to check on the problem. If that's not possible tow her in on a low profile flat bed trailer, Cheaper than a new motor. Kurt On Nov 17, 2010, Don Bradner
11-22-2010, 07:03
11-24-2010, 12:11
> > Check the codes on the engine - hold down the engine test button, and count the flashes, which will be in sets of two. There may be several codes, hold it down until it repeats and record all codes. Tell us what you get. Howdy, Don. Here are the codes, read this morning: 13, 16, 24, 36, 43, 44, 46, 53. TIA, Jack and Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX Winter Buena Vista, CO Summer > > On 11/17/2010 at 1:54 PM txfulltimers wrote: > > >Howdy. > >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, > >TX. > > > >We are having real problems with the Bird. The Check Engine light and > >the Test Engine lights come on and a buzzer buzzes. The engine loses > >power, kinda stumbles for about 4 seconds. Then it recovers and goes on > >as normal. We thought that this was caused by the coolant level sensor > >which was dying. Jack replaced that sensor but it didn't solve this > >problem. One other thing is the tach. The tach needle will wander then > >settle down, then wander again. We want to get the coach down to Clyde > >in Seguin, TX, BUT I am really worried that we might get stranded on the > >side of a road. Suggestions, ideas for a solution would be most > >welcomed. > > > >Jack and Liz Pearce > >1993 BB WLWB > >Currently in Wylie, TX > |
11-24-2010, 12:57
OK, here is what they mean:
13 Coolant Level Low Voltage 16 Coolant Level High Voltage 24 Fuel Temperature Voltage Low 36 Oil Pressure Sensor Volatge Low 43 Low Coolant for 7 seconds. Will also trigger Stop Engine 44 Oil or Coolant over temperature. Will also trigger Stop Engine 46 Low Battery Voltage for more than 30 seconds 53 EEPROM memory failure (internal DDEC) Note that these are historical codes and they do not tell you when they occurred. Whenever I find that I have any codes (they can be spurious) I get them cleared. "No Codes" is a 25 On 11/25/2010 at 12:11 AM txfulltimers wrote: >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> Check the codes on the engine - hold down the engine test button, and >count the flashes, which will be in sets of two. There may be several >codes, hold it down until it repeats and record all codes. Tell us what >you get. > >Howdy, Don. >Here are the codes, read this morning: > >13, 16, 24, 36, 43, 44, 46, 53. > >TIA, >Jack and Liz >Regards, >Jack and Liz Pearce >Fulltiming in a 1993 Wanderlodge WB40 >D'Hanis, TX Winter >Buena Vista, CO Summer > > > > > > >> >> On 11/17/2010 at 1:54 PM txfulltimers wrote: >> >> >Howdy. >> >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, >> >TX. >> > >> >We are having real problems with the Bird. The Check Engine light and >> >the Test Engine lights come on and a buzzer buzzes. The engine loses >> >power, kinda stumbles for about 4 seconds. Then it recovers and goes >on >> >as normal. We thought that this was caused by the coolant level >sensor >> >which was dying. Jack replaced that sensor but it didn't solve this >> >problem. One other thing is the tach. The tach needle will wander >then >> >settle down, then wander again. We want to get the coach down to >Clyde >> >in Seguin, TX, BUT I am really worried that we might get stranded on >the >> >side of a road. Suggestions, ideas for a solution would be most >> >welcomed. >> > >> >Jack and Liz Pearce >> >1993 BB WLWB >> >Currently in Wylie, TX >> |
11-24-2010, 13:11
Sounds like 53 alone would cover all bases with low voltage. This has been a
bane of DDEC since the dawn of time. Corroded pins on a molex plug? Intermittent connectors from the voltage source. Bad batteries dirty connections. And on and on. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "Don Bradner" Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 24 Nov 2010 16:57:06 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: OUR 1993 BB IS SICK !!! HELP!! OK, here is what they mean: 13 Coolant Level Low Voltage 16 Coolant Level High Voltage 24 Fuel Temperature Voltage Low 36 Oil Pressure Sensor Volatge Low 43 Low Coolant for 7 seconds. Will also trigger Stop Engine 44 Oil or Coolant over temperature. Will also trigger Stop Engine 46 Low Battery Voltage for more than 30 seconds 53 EEPROM memory failure (internal DDEC) Note that these are historical codes and they do not tell you when they occurred. Whenever I find that I have any codes (they can be spurious) I get them cleared. "No Codes" is a 25 On 11/25/2010 at 12:11 AM txfulltimers wrote: >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> Check the codes on the engine - hold down the engine test button, and >count the flashes, which will be in sets of two. There may be several >codes, hold it down until it repeats and record all codes. Tell us what >you get. > >Howdy, Don. >Here are the codes, read this morning: > >13, 16, 24, 36, 43, 44, 46, 53. > >TIA, >Jack and Liz >Regards, >Jack and Liz Pearce >Fulltiming in a 1993 Wanderlodge WB40 >D'Hanis, TX Winter >Buena Vista, CO Summer > > > > > > >> >> On 11/17/2010 at 1:54 PM txfulltimers wrote: >> >> >Howdy. >> >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, >> >TX. >> > >> >We are having real problems with the Bird. The Check Engine light and >> >the Test Engine lights come on and a buzzer buzzes. The engine loses >> >power, kinda stumbles for about 4 seconds. Then it recovers and goes >on >> >as normal. We thought that this was caused by the coolant level >sensor >> >which was dying. Jack replaced that sensor but it didn't solve this >> >problem. One other thing is the tach. The tach needle will wander >then >> >settle down, then wander again. We want to get the coach down to >Clyde >> >in Seguin, TX, BUT I am really worried that we might get stranded on >the >> >side of a road. Suggestions, ideas for a solution would be most >> >welcomed. >> > >> >Jack and Liz Pearce >> >1993 BB WLWB >> >Currently in Wylie, TX >> ------------------------------------ Yahoo! Groups Links |
11-24-2010, 15:39
I agree. I run VMSPc, and one of the things it shows me is the voltage the DDEC
is seeing. I was amazed at how much it jumped around, and how low it would go (11 to 13.4 was the range I initially saw). My dash gauge was steady in the high 13 range. Cleaning grounds helped, and I got the most stability when I added a heavy jumper from the ground side of the batteries to a bolt on the engine itself. I still see steady swings in the DDEC voltage, but now it is 12.8-13.4, roughly. On 11/25/2010 at 1:11 AM Ralph wrote: >Sounds like 53 alone would cover all bases with low voltage. This has >been a bane of DDEC since the dawn of time. Corroded pins on a molex plug? >Intermittent connectors from the voltage source. Bad batteries dirty >connections. And on and on. >Safe travels, Ralph & >Charolette Fullenwider >'84 FC35 "Ruff Diamond" >Duncan, Oklahoma >Sent via BlackBerry by AT&T > >-----Original Message----- >From: "Don Bradner" >Sender: WanderlodgeForum@yahoogroups.com >Date: Wed, 24 Nov 2010 16:57:06 >To: >Reply-To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: OUR 1993 BB IS SICK !!! HELP!! > >OK, here is what they mean: >13 Coolant Level Low Voltage >16 Coolant Level High Voltage >24 Fuel Temperature Voltage Low >36 Oil Pressure Sensor Volatge Low >43 Low Coolant for 7 seconds. Will also trigger Stop Engine >44 Oil or Coolant over temperature. Will also trigger Stop Engine >46 Low Battery Voltage for more than 30 seconds >53 EEPROM memory failure (internal DDEC) > >Note that these are historical codes and they do not tell you when they >occurred. Whenever I find that I have any codes (they can be spurious) I >get them cleared. "No Codes" is a 25 > >On 11/25/2010 at 12:11 AM txfulltimers wrote: > >>--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >>wrote: >>> >>> Check the codes on the engine - hold down the engine test button, and >>count the flashes, which will be in sets of two. There may be several >>codes, hold it down until it repeats and record all codes. Tell us what >>you get. >> >>Howdy, Don. >>Here are the codes, read this morning: >> >>13, 16, 24, 36, 43, 44, 46, 53. >> >>TIA, >>Jack and Liz >>Regards, >>Jack and Liz Pearce >>Fulltiming in a 1993 Wanderlodge WB40 >>D'Hanis, TX Winter >>Buena Vista, CO Summer >> >> >> >> >> >> >>> >>> On 11/17/2010 at 1:54 PM txfulltimers wrote: >>> >>> >Howdy. >>> >Right now we are at the East Fork COE park at Lake Lavon, near Wylie, >>> >TX. >>> > >>> >We are having real problems with the Bird. The Check Engine light and >>> >the Test Engine lights come on and a buzzer buzzes. The engine loses >>> >power, kinda stumbles for about 4 seconds. Then it recovers and goes >>on >>> >as normal. We thought that this was caused by the coolant level >>sensor >>> >which was dying. Jack replaced that sensor but it didn't solve this >>> >problem. One other thing is the tach. The tach needle will wander >>then >>> >settle down, then wander again. We want to get the coach down to >>Clyde >>> >in Seguin, TX, BUT I am really worried that we might get stranded on >>the >>> >side of a road. Suggestions, ideas for a solution would be most >>> >welcomed. >>> > >>> >Jack and Liz Pearce >>> >1993 BB WLWB >>> >Currently in Wylie, TX >>> > > > > > >------------------------------------ > >Yahoo! Groups Links > > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
