new wanderlodge owner needs help starting furnaces
12-09-2010, 03:19
Hi.
I got a 1982 fc35 last month and we are checking systems out. Can someone walk me through starting the furnaces and cooktop? It had an empty propane tank that I just filled. 102.00 for 3/4 of a tank. Ouch. Cant wait to fill the 265 gal diesel tank. HaHa. |
12-09-2010, 19:08
Hey,
Look under the dinette seat in the aisle there is a switch that has to be on for any of the propane to operate. Had the same problem when we got our bird last year. Hope this fixes the problem. --- In WanderlodgeForum@yahoogroups.com, "rlrueter" > > Hi. > I got a 1982 fc35 last month and we are checking systems out. > Can someone walk me through starting the furnaces and cooktop? > It had an empty propane tank that I just filled. > 102.00 for 3/4 of a tank. Ouch. Cant wait to fill the 265 gal diesel tank. HaHa. > |
12-10-2010, 01:58
.... and the diesel is the CHEEP part of owning one of these beasts! I opened up
my propane tank and replaced some gaskets this past summer. Once I closed up and refilled the LP tank, all I had to do was turn on the leak detector thingy so that the gas would come on and then I just stood at the stove with a lit match against one burner and waited for the air to purge out of the lines. Once all 4 burners and the pilot were lit, I proceeded to turn on the reefer (the one you keep drinks in) and then let the furnaces cycle a few times. Some of them will try to re-ignite if they don't succeed the first time, but mine don't. See if they come on within 30 seconds of the blower turning on and if not, turn them off and try again. After doing this 2 or 3 times, they should all ignite with no problems. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "rlrueter" > > Hi. > I got a 1982 fc35 last month and we are checking systems out. > Can someone walk me through starting the furnaces and cooktop? > It had an empty propane tank that I just filled. > 102.00 for 3/4 of a tank. Ouch. Cant wait to fill the 265 gal diesel tank. HaHa. > |
12-10-2010, 04:34
