Engine won't start or Primus
02-28-2011, 11:19
Nelson,
I have Interstate batteries for the same reason as Roger, easiest thing to do
and convenient to find on the road for replacements.
As for the 14V reading on your dash meters, that sounds like a bogus surface
charge reading if the engine cranks slowly and does not start. You will need to
load test the batteries individually to see what happens to the voltage reading
then. There's probably a dry cell or bad cell somewhere on one or more of the
start batteries.
In the meantime, if you have not already tried it, use the aux battery switch on
the dash to tie the battery banks together and try to start again. If that
doesn't work, I would just use battery jumper cables from a 12V neg ground toad
to the jumper pins inside the rear door to get it started, until you can get the
batteries checked out.
Good luck.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "nelsons" wrote:
> Thanks Roger,
> Let see what happens.
> Have a great day.
> Nelson
> --- In WanderlodgeForum@yahoogroups.com, Roger W Webb wrote:
> > Oh no!. You have asked one of the most dreaded questions on the forum ...
what battery is the best?? ... good luck, there are lots of opinions. I've got
Interstate, but that is just because it was easy to do. Wait for 24 hours and
I'm sure you'll have at least 6 different recommendations.
> > Now I'm not making fun of anyone ... I just know batteries and tires
generate lots of responses. Have fun folks.
> > Roger Webb - Cedar Rapids, IA
> > 91 WL - sitting in NC
> > -----Original Message-----
> > From: nelsons
> > To: WanderlodgeForum
> > Sent: Mon, Feb 28, 2011 8:30 am
> > Subject: [WanderlodgeForum] Re: Engine won't start or Primus
> > Thank you Roger,
> > I think you are correct about the condition of the batteries. Could you
recommend which ones to purchase for replacement? Could not find the Battery
Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, what
would all we do without this forum.
> > Thanks
> > Nelson Slinkman
> > 1994 WB 40'
> > Westminster, Md
> > > IMO your engine batteries are just too weak. If charging them does get
some cranking power, trying jumping them (if you are a member of Good Sam or
other service, it may be worth the call). Even then, if you have one really bad
battery, jumping may not help and replacing them may be your next alternative.
The gages on the dash really only give you an indication of voltage at the
moment and although lookin' good, may not be a good indication of cranking
power.
> > > Tying you house and engine batteries together with the switch on the dash
could get you some cranking power, and heating up the batteries may help (my
switch for the battery heat is under the sink in my 91WL). But even those
assists may not overcome a bad or weak bank of batteries.
> > > 91WL (sitting in NC)
> > > From: nelsons
> > > Sent: Mon, Feb 28, 2011 7:51 am
> > > Hello Mike,
> > > I could not find any switch for electric heater behind the pull down
> > > drawer. There was only an "start Gen" "LP on/off" and water pump switch.
Yes, the switch was "on" to charge both sets of batteries. I am sure the ether
tank is empty I have had this bus for 10 years and never used it. The bus only
has 31000 miles on it.
> > > Thanks for your help.
> > > Nelson SLinkman
> > > 1994 WB 40'
> > > Westminster, Md
> > > --- In WanderlodgeForum@yahoogroups.com, "Steve Quandt" wrote:
> > > > If it is set up the same as my 1993 pull down the drawer front under the
> > > > kitchen sink, there should be a switch there for the electric engine
heater.
> > > > For this to work you need to be plugged in or on your generator. When
you
> > > > were parked did you tie the engine batteries to the house so they would
be
> > > > charged? If not there is a switch on the dash AUX Battery, if it is off
> > > > turn to on to on to charge the engine batteries.
> > > > The cold start switch goes to an ether cylinder in the engine bay that
is
> > > > most likely empty.
> > > > Steve Quandt 1993 PT40
> > > > Iron Mountain, MI
> > > > Now in WARM Marble Falls TX
> > > > _____
> > > > From: WanderlodgeForum@yahoogroups.com
> > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of nelsons
> > > > Sent: Monday, February 28, 2011 11:26 AM
> > > > To: WanderlodgeForum@yahoogroups.com
> > > > Subject: [WanderlodgeForum] Engine won't start or Primus
> > > > Hello,
> > > > I have a 1994 WB with an 8v92. I have been away for 4 months and just
got
> > > > back this past weekend. I wanted to start the engine so I tried starting
> > > > Primus in order to pre-warm the engine due to the cold temperature we've
had
> > > > for a few months. The Primus would not start. I checked the Propane
switch,
> > > > and it was on, the stove was working and so was the refrigerator. I
tried to
> > > > turn it on a few times incase there was and air in the line, but it
never
> > > > started. It there another safety switch for the Primus? I started the
engine
> > > > and the primus before I left and all worked properly.
> > > > When I try to start the engine it turns very slowly and does not turn
fast
> > > > enough to start.
> > > > The only thing that I noticed was the "Neutral" light on the
transmission
> > > > panel is on.
> > > > Does the 1994 Bird have an electric heated for the engine? I saw a
switch
> > > > that is on the right side of the consul that says cold start.
> > > > Any help would be appreciated.
> > > > Thanks
> > > > Nelson Slinkman
> > > > 1994 WB
> > > > Westminster, Md
02-28-2011, 12:02
When I was in Ft Worth, I bought T105 Trojans. They lasted quite a few years. When I was in Austintown, Ohio last year, batteries died. All that was available was Crown batteries. Put them on the coach and off and running. Any battery new is a lot better then any real old ones
83 PT40
Weatherford, Tx 76086
817-475-3991
--- On Mon, 2/28/11, Roger W Webb wrote:
Subject: Re: [WanderlodgeForum] Re: Engine won't start or Primus
Date: Monday, February 28, 2011, 1:43 PM
Oh no!. You have asked one of the most dreaded questions on the forum ... what battery is the best?? ... good luck, there are lots of opinions. I've got Interstate, but that is just because it was easy to do. Wait for 24 hours and I'm sure you'll have at least 6 different recommendations.
Now I'm not making fun of anyone ... I just know batteries and tires generate lots of responses. Have fun folks.
Thank you Roger,
I think you are correct about the condition of the batteries. Could you recommend which ones to purchase for replacement? Could not find the Battery Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, what would all we do without this forum.
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
> IMO your engine batteries are just too weak. If charging them does get some cranking power, trying jumping them (if you are a member of Good Sam or other service, it may be worth the call). Even then, if you have one really bad battery, jumping may not help and replacing them may be your next alternative. The gages on the dash really
only give you an indication of voltage at the moment and although lookin' good, may not be a good indication of cranking power.
> Tying you house and engine batteries together with the switch on the dash could get you some cranking power, and heating up the batteries may help (my switch for the battery heat is under the sink in my 91WL). But even those assists may not overcome a bad or weak bank of batteries.
> From: nelsons
> To: WanderlodgeForum <WanderlodgeForum@yahoogroups.com>
> Subject:
> Hello Mike,
> drawer. There was only an "start Gen" "LP on/off" and water pump switch. Yes, the switch was "on" to charge both sets of batteries. I am sure the ether tank is empty I have had this bus for 10 years and never used it. The bus only has 31000 miles on it.
> Nelson SLinkman
> 1994 WB 40'
> Westminster, Md
> > kitchen
sink, there should be a switch there for the electric engine heater.
> > For this to work you need to be plugged in or on your generator. When you
> > were parked did you tie the engine batteries to the house so they would be
> > The cold start switch goes to an ether cylinder in the engine bay that is
> > most likely empty.
> > Iron Mountain, MI
> > _____
> > Hello,
> > I have a 1994 WB with an 8v92. I have been away for 4 months and just got
> > back this past weekend. I wanted to start the engine so I tried starting the
Primus in order to pre-warm the engine due to the cold temperature we've had
> > for a few months. The Primus would not start. I checked the Propane switch,
> > and it was on, the stove was working and so was the refrigerator. I tried to
> > turn it on a few times incase there was and air in the line, but it never
> > started. It there another safety switch for the Primus? I started the engine
> > When I try to start the engine it turns very slowly and does not turn fast
> > enough to start.
> > The only thing that I noticed was the "Neutral" light on the transmission
> > panel is on.
> > Does the 1994 Bird have an electric heated for the engine? I saw a switch
> > Thanks
> Nelson Slinkman
> > 1994 WB
> > Westminster, Md
02-28-2011, 17:00
Oh Yes, Trojans are great batteries. I have also learned on this forum that oil is also a thing to discuss, and subject to differences of opinion. I think that Shawn from Pa. got me to looking at batteries, {Pls. don't shoot me in case I mis-spelled your name Shawn}, and this I have learned. Sams Club sells a excellent 6 volt golf cart battery, if you use that type, but if not here is the good news Their batteries are mfg. by Johnson Controls. This company has a excellent reputation, and they manufacture these batteries; Interstate, Sears Diehard, as well as the Sams Club Golf cart Batteries, as well as others. I have Interstate batteries at present, and have got great service from them. I will buy the Sams Club batts next time, because when I checked the price early last year, they were approx. $74.00 ea., vs. the Interstate, which were around $105. Good Luck, George Burke 1977 FC31SB Charlotte  P.S. The batts that Wal-Mart sells are not the same, they are mfg. by Excide, and are not the same quality.
83 PT40
817-475-3991
To: WanderlodgeForum <"WanderlodgeForum@yahoogroups.com">
Thank you Roger,
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
> From: nelsons
> Subject:
> Hello Mike,
> Nelson SLinkman
> 1994 WB 40'
> Westminster, Md
> > kitchen
> > most likely empty.
> > Iron Mountain, MI
> > _____
> > Hello,
> > enough to start.
> > panel is on.
> > Thanks
> Nelson Slinkman
> > 1994 WB
> > Westminster, Md
03-01-2011, 07:38
Thank you all for the information.
FOLLOW UP ON ENGINE WON'T START
After turning on the Primus for 2 hours the engine started right up. Not bad for
setting for 4 months.
The only problem I see is the Level warning light is on even thought they are
completely up.
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
> > *Ernie Ekberg*
> > *83 PT40*
> > *Weatherford, Tx 76086*
> > *817-475-3991*
> > *http://www.ernieekbergflooring.net*
> > --- On *Mon, 2/28/11, Roger W Webb * wrote:
> > From: Roger W Webb
> > From: nelsons
> > Thank you Roger,
> > Thanks
> > Nelson Slinkman
> > 1994 WB 40'
> > Westminster, Md
> > --- In
WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compose?to=Wa\
nderlodgeForum%40yahoogroups.com>,
> > alternative. The gages on the dash really only give you an indication of
> > > From: nelsons
http://us.mc812.mail.yahoo.com/mc/compose?to=W\
anderlodgeForum%40yahoogroups.com>
> > > Hello Mike,
> > > Nelson SLinkman
> > > 1994 WB 40'
> > > Westminster, Md
> > > --- In
> > the
> > heater.
> > you
> > be
> > is
> > > > most likely empty.
> > > > Iron Mountain, MI
> > > > _____
> > > > From:
[mailto:WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compo\
se?to=WanderlodgeForum%40yahoogroups.com>]
> > > > To:
> > > > Hello,
> > got
> > starting the
> > we've had
> > switch,
> > tried to
> > never
> > engine
> > fast
> > > > enough to start.
> > transmission
> > > > panel is on.
> > switch
> > > > Thanks
> > > > Nelson Slinkman
> > > > 1994 WB
> > > > Westminster, Md
03-01-2011, 12:19
Nelson,
Good going!
So how did you get the Primus to start? As previously posted, they would not start.
And I guess the batteries were OK after all?
Thanks for the update.
Date: Tuesday, March 1, 2011, 1:38 PM
After turning on the Primus for 2 hours the engine started right up. Not bad for setting for 4 months.
The only problem I see is the Level warning light is on even thought they are completely up.
Thanks
Nelson Slinkman
1994 WB 40'
Westminster, Md
> > *Ernie Ekberg*
> > *83 PT40*
> > *817-475-3991*
> > From: Roger W Webb
> > From: nelsons
> > Thank you Roger,
> > Thanks
> > Nelson Slinkman
> > 1994 WB 40'
> > Westminster, Md
> > --- In WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compos...groups.com>,
> > > From: nelsons
> > > To: WanderlodgeForum <WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compos...groups.com>
> > > Hello Mike,
> > > Nelson SLinkman
> > > 1994 WB 40'
> > > Westminster, Md
> > the
> > heater.
> > you
> > be
> > is
> > > > most likely empty.
> > > > Iron Mountain, MI
> > > > _____
> > > > From: WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compos...groups.com>
> > > > [mailto:WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compos...groups.com>]
> > > > To: WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compos...groups.com>
> > > > Hello,
> > got
> > starting the
> > we've had
> > switch,
> > tried to
> > never
> > engine
> > fast
> > > > enough to start.
> > transmission
> > > > panel is on.
> > switch
> > > > Thanks
> > > > Nelson Slinkman
> > > > 1994 WB
> > > > Westminster, Md
