FC Dash Oil Leak
03-28-2011, 10:46
FC Dash Oil Leak
I've been tracking down the source of some oil drips coming from under the dash.
Not a flood yet, but I don't want to ignore it until it gets real ugly. The wiring in this area is so thick it's really hard to get a good look at where it's coming from. I've removed the upper and lower dash panels and opened up the outside front panel on the driver's side. Thus far, I've observed the following: 1. Tubing from the engine oil pressure gauge to the quick disconnect is intact. 2. Tubing quick disconnect is dry - no leak there. 3. There appears to be an alarm stat labeled "Cadillac" below the quick disconnect. The leak appears to be coming from this gizmo or immediately below it. Questions: 1. Has anyone had a similar problem? 2. If so, how did you resolve it? 3. Access to this area is VERY limited, what did you do to get into the alarm stat? Best solution may be to abandon the pressure stat and old tubing to the engine, if I can figure out where the pressure tap is, and run a new line. All help/suggestions appreciated. Eric Johnson 84FC35SBWL2 |
03-29-2011, 11:44
FC Dash Oil Leak
Sorry to have bothered you folks on this site with this problem. Got the answer
I needed on the Wanderlodge Owners Group Forum. NH Bill can help you if any of you have a similar problem. Eric Johnson 84FC35SBWL2 |
03-29-2011, 12:08
FC Dash Oil Leak
Hi Eric
Happy to hear you figured it out with Billââ¬â¢s help.
He is a lot of help.
Fred & Jeanne Hulse Morristown,Arizona 97 WLWB41 |
