1991 WL PT 40
06-30-2005, 20:27
1991 WL PT 40
Al, if you come to Montana and you can either go south from Livingston or
Bozeman. Both roads are great with outstanding scenery. Ernie- was in wwest
yellowstone last week
07-01-2005, 00:45
1991 WL PT 40
Sent: Thursday, June 30, 2005 9:17 PM
Subject: RE: [WanderlodgeForum] Re: 1991 WL PT 40
Hi David When your engine temp.reach 215 F on a 8V92 it was already a
done deal your engine was going to be toast.This is not my opinion it's Detroit
diesel they told me not to let my engine water temp.get over 110 F .Five years
ago i had to replace my raditor core $1,800 for a new core.
Bob Loomas 85 PT 36
Bob; yes it was Alt. rt 14 ,we were up about 8 miles into the climb when the
engine started blowing anti-freeze out the raditor cap. the odd thing my
water temp gauge never got over 220 F the whole time . I have the old
raditor core in my pickup bed ,I's amazing it didn't over heat sooner. You
just touch the fins and they crumble into dust,this goes down two and three
inches into the core. I took it to my raditor repair shop and he said it's
just junk and there is no repair. He said it was from the acids from the
road that rotted the core.
>From: "Bob & Carol Howald`"
>Subject: [WanderlodgeForum] Re: 1991 WL PT 40
>Date: Wed, 29 Jun 2005 11:39:11 -0000
YAHOO! GROUPS LINKS
07-01-2005, 03:21
1991 WL PT 40
All Detroits, or just the Series 60? Any idea about the 8V92? My normal op
temp is around 190, and when it gets to 200 (seldom happens) I turn on the
Fan Overide switch. That cools it down pretty fast (down to 170 or so in just
a few minutes).
Kevin Mc
YL CA
86 38 PT
07-01-2005, 04:44
1991 WL PT 40
Sorry to hear that. What a bummer.
Moderator
--- In WanderlodgeForum@yahoogroups.com, "David Heibult"
> Ron. It was the coach engine that shot craps .IJt was from the
main raditor
> being plugged up.Dave 1991 WLPT 40
> >From: "ronmarabito2002"
> >Date: Thu, 30 Jun 2005 14:13:27 -0000
07-01-2005, 06:39
1991 WL PT 40
This confirms what Detroit Diesel told me about
the Series 60. They said, "keep the temperature
below 210 deg F, and anything over 220 deg F.
will cause engine damage".
David Brady
'02 LXi, Smokey
Virginia
> From: David Heibult
years ago i had to replace my raditor core $1,800 for a new core.
> Bob Loomas 85 PT 36
> YAHOO! GROUPS LINKS
>Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.8.8/35 - Release Date: 6/30/2005
07-01-2005, 06:54
1991 WL PT 40
Bob. Detroit dealer said at 200 F you better get it shut down now. from
experence I can tell you he is right. .I won't make that mistake again. Dave
1991WLPT 40 & 82 FC 35
>From: bobloomas
>Subject: Re: [WanderlodgeForum] Re: 1991 WL PT 40
>Date: Fri, 01 Jul 2005 07:45:18 -0500
07-01-2005, 09:19
1991 WL PT 40
All electronic controlled Detroits are equipped with a high
temperature shut-off. What temperature is it set for? Anyone know?
Moderator
--- In WanderlodgeForum@yahoogroups.com, David Brady
> David Brady
> '02 LXi, Smokey
> Virginia
> > From: David Heibult
was already a done deal your engine was going to be toast.This is
110 F .Five years ago i had to replace my raditor core $1,800 for a
new core.
> > Bob Loomas 85 PT 36
climb when the
thing my
the old
sooner. You
two and three
he said it's
from the
> > YAHOO! GROUPS LINKS
of Service.
> >Yahoo! Groups Links
6/30/2005
07-01-2005, 09:25
1991 WL PT 40
One of the problems with that statement is: All temperature guages
are accurate plus the fact that with a 190 degree thermostat, it is
easy to get to 200 degrees while cycling the thermostat and climbing
a steep grade. When my unit is opening and closing, my guage moves
from as low as 180 degrees to 200 degrees. This is mostly when I
get on the road after the coach has been sitting for a while.
Moderator
from
again. Dave
> >From: bobloomas
07-04-2005, 04:03
1991 WL PT 40
Bob. The raditor got hot because the cooling fins were pluged with dirt and
leaves and the fins themself were rotted from vroad acids and would crumble
on touch. Dave 1991 WLPT 40
>Date: Thu, 30 Jun 2005 14:44:31 -0000
07-04-2005, 04:13
1991 WL PT 40
Al. We just came thou the east gate, It's not shut down it has one way
traciffic running with a pilot car expect about a 25 min. delay at most .The
second time I tried to go to Yellowstone we went thur Dayton Wy. It's exit
9 on I-29 the route isno# 14 and you come out at shell Wy. and Greybull
.It's not a rough as hwy 16. The other plus is that you can stay at Cody Wy.
and there is a lots of things to see and do. You need at least 2 days at the
Windchester museum ,It's a great palce to visit,You can dry camp on your way
to Yellowstone from Cody .Just beware there is wild bears in that
country.Dave 1991 WLPT 40
>From: "Al"
>Date: Fri, 01 Jul 2005 03:09:38 -0000
