Clearance required
10-26-2011, 02:34
Clearance required
BMC 37' is more like 37' 8" or 10" in length, with no tow bar attached. Well
over 38' with a towbar on and folded up.
Dan
94 BMC 37'
--- In WanderlodgeForum@yahoogroups.com, "Joe" wrote:
> Let me thank all of you for the info and insight.
> It appears that a FC would be fine and most likely a BMC as I'm also limited
in building depth of 37 feet being the absolute maximum I could put inside and
still walk (squeeze) around the back of the unit.
> Thanks again,
> Joe
> --- In WanderlodgeForum@yahoogroups.com, billpatty@ wrote:
> > Depending the type of door and door track mechanism, the door may be able to
be raised higher into the ceiling. Other have lowered the floor especially at
the entry point.
> > Bill Pape 1988FC Michigan
> > > Bluebirds seem to be 12 feet, plus or minus. The same model can vary by
inches, depending on tire size , ride height, & stuff on the roof. If you are
considering a 12 foot door, some Birds will clear others may not. If a few
inches are an issue, dumping the suspension will help lower the height by a few
more inches. Several Birds were measured last year at a Rally, there is a chart
in post #20.
> > > http://www.wanderlodgeownersgroup.com/fo...347&page=2
> > > > I'm still at it, trying to find a suitable coach that will fit in my
warehouse.
> > > > Can anyone tell me the clearance height of a BlueBird BMC 37?
> > > > I realize this is not a BMC forum, but just maybe someone here knows and
would tell me.
> > > > Thanks,
> > > > Joe
> > > > Indian Harbour Beach, FL
10-26-2011, 04:18
Clearance required
My '88 FC 35' has the front air unit removed from the top. It has an
11 foot clearance, which includes a storage box on the roof. It may be
more if that AC unit is still there.
Dave Swan
'88 FC Silver edition
