Coach Door Build
03-21-2013, 09:03
Coach Door Build
Anyone out there know how the skin of the door on a 92WB40 is attached to the
frame? Mine is separating. I can't tell if it was spot welded or attached
with an adhesive.
03-21-2013, 09:43
Coach Door Build
Hi Ron
On my SP36 the skin was tack welded to the frame and was separating in a couple areas. I used some JB weld and clamped the areas for drying time and it turned out good.
Fred & Jeanne Hulse
03-21-2013, 09:51
Coach Door Build
Close but maybe "no cigar" Ron:
92WB40 is attached to the frame? Mine is separating. I
can't tell if it was spot welded or attached with an
adhesive.
BMC37 1995 -- spot welded and not well enough to survive thru 2012.
Vibration got it I guess... Half dozen broken spots, ugly screw
patch until a good repair shows up.
Cheers
Geo
03-21-2013, 14:34
Coach Door Build
Thanks Fred: I had been thinking of of using a common construction adhesive,
but JB Weld is probably more appropriate.
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Hi Ron
turned out good.
> Fred & Jeanne Hulse
03-21-2013, 14:50
Coach Door Build
Years ago Bluebirds fix for the broken welds was to use polyurethane. I did this for my 94 and it worked great. My welds broke because the door rubber was too robust and to completely close the door you had to really slam it. My 99 has the same robust rubber seal so I never close it tight untill I am about to hit the road. If the welds break on this one I will use the same polyurethane, clamp over night and all will be well. While the poly secures very well it also has a certain amount of flexibility. I would think anything rigid might just break again
On 21 March 2013 18:34, ronmarabito2002 <"remarabito@gmail.com"> wrote:
Thanks Fred: I had been thinking of of using a common construction adhesive, but JB Weld is probably more appropriate.
--- In "WanderlodgeForum%40yahoogroups.com", "Fred Hulse" wrote:
> Hi Ron
> Fred & Jeanne Hulse
Rob, Sue and Joey Robinson
03-22-2013, 05:56
Coach Door Build
Polyurethane to glue body panels on is
pretty standard in today's vehicle manufacturing. Lots of
production cars have glued on door skin. Go to a Automotive body
repair shop and ask for their recommended adhesive.
David Brady
'02 Wanderlodge LXi
"Fred Hulse" "fhulse@..." wrote:
> Hi Ron
> Fred & Jeanne Hulse
