FC quit running
07-07-2005, 06:51
FC quit running
Thanks for your comments Dan, they fit perfectly with what I am
experiencing. I am doing last resort procedures. Last night took me five
hours to remove the two foot long flexible line running between the copper
line and the filter on the cat. It looks original and in excellent
condition, so I was/am disenchanted with the hope that this is the problem.
In the next two hours I will get a new line made and install and run test
probably tomorrow.
Appreciate very much you sharing your experience.
dandarst86fc35rbhuntleyil.
>From: "Dan Carr"
>Subject: [WanderlodgeForum] Re: FC quit running
>Date: Wed, 06 Jul 2005 16:39:19 -0000
>This may not be applicable, but we had similar experiences on our
>DD6v92 which turned out to be aged fuel lines. Everything would work
>until we had been running a few hours (the engine compartment warmed
>up) and then when you lifted your foot from the throttle, the fuel
>line would collapse causing fuel starvation. They looked normal and
>the DD shop said they were good.
>Just something you might want to check if the fuel lines haven't been
>replaced. We replaced and everything works fine.
>Dan Carr
>82PT40 6V92
>Columbiana, OH
>--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote:
> > Thanks everyone for the quick feedback. Made it home at 8pm central
>time.
> > Took 8 hours to do a five hour trip. Cat died three times, lack of
>fuel flow
> > at high demand. Changed the filters, priming both with the facet
>pusher
> > pump on a dash switch we put in. So pump works. Next step is to take
>racor
> > apart to try and find something causing flow restriction. Have not
>had this
> > problem since fall 03, but its back again now.
> > Thanks again.
> > >From: "pattypape"
> > >Date: Tue, 05 Jul 2005 02:06:56 -0000
> > >Jay.
> > >I think you are now beyond my knowledge, maybe the experts will
> > >check in after their 4th July party.
> > >The low fuel in the primary filter should be a clue. Great idea to
> > >clean out the Racor. About a week or two ago there was a thread on
> > >blowing out the fuel lines toward the tank and then forward to the
> > >primary filter with air forced into the racor fuel lines when
> > >disconnected.
> > >Then, I guess it is onto the injectors, Bleed those injectors, until
> > >the fuel runs clear. I can easily reach five of them, and the Cat
> > >always starts.
> > >Bill 88 FC
> > >--- In WanderlodgeForum@yahoogroups.com, "Jay Darst"
> > > wrote:
> > > > Appreciate the suggestions on the Facet pump...
> > > > Dan was able to get started again...though can only run in high
> > >gear
> > > > at 50mph. When a hill climb is required, he must not push the
> > > > throttle too hard as he will have symptoms of low fuel delivery
> > >(such
> > > > as very little or no boost).
> > > > When the speed reduces to a point where 3rd gear(of 4 gears)is
> > >being
> > > > used, the fuel and boost return to normal full power. However, as
> > > > soon as 4th gear is engaged, almost immediately, boost level
> > >reduces
> > > > to 1-2psi and thus away goes the horse power. as we slow down and
> > > > then back to 3rd gear, an immediate 10pounds of boost and all the
> > > > horses are back.
> > > > Going down a hill with throttle wide open, reached about 63mph
> > >with
> > > > 10pounds of boost, then, while continuing the downhill run, the
> > > > boost reduced to 1-2pounds and the Bird slowed to 50mph. Where it
> > > > will run all day, with 1-3 pounds of boost.
> > > > After changing the Racor, it ran bad, as before the change. So he
> > > > stopped and changed the secondary fuel filter, reffered to as
> > > > the "CAT" filter, I suppose to differentiate from the Racor
> > >filter.
> > > > Noticed that the fuel level in the Cat filter was down maybe 2
> > > > inches in the filter.
> > > > Dan replaced the Cat filter with new, primed with the Facet pump
> > >and
> > > > the little hand primer pump, and the bird started and ran, BUT, NO
> > > > CHANGE. Still not making power as it should.
> > > > Generator has been running the whole time, no stumbles, no
> > >problems.
> > > > The Racor gage is at 1 or 2 inches of vacuum, so normal.
> > > > The filters are fresh.
> > > > The fuel is fresh
> > > > The wire to the "Fuel Shut Off Solenoid" is good. By the way, that
> > > > wire, if broken, causes the Cat to NOT run at all. Been there done
> > > > that.
> > > > A fuel delivery issue for sure.
> > > > Plans are to remove the bottom bowl from the Racor and clean the
> > > > swirl tube and check ball.
> > > > What else?
> > > > Thanks for all your help!
> > > > Jay Darst
> > > > working toward a fix for 1986 FC 35 RB
> > > > and an owner of the far superior and slightly better(on some days)
> > > > 85PT40 ;~)
> > > > --- In WanderlodgeForum@yahoogroups.com, randydupree
> > > > wrote:
> > > > > also,on my sister in laws coach the wire going to the fuel
> > >sol.on
> > > > the pump broke off,she put a new end on the wire and that fixed
> > >it.
> > > > Randy
> > > > > ----- Original Message -----
> > > > > From: samax8
> > > > > Sent: Monday, July 04, 2005 5:43 PM
> > > > > -Could be air in the fuel. If it will run at all, watch water
> > > > > separator for air bubbles. If there, may be defective water
> > > > separator.
> > > > > I had that situation and replacing H2O separator solved the
> > > > problem.
> > > > > Bill
> > > > > 82FC33
> > > > > wrote:
> > > > > > Hey any of you FC owners, brother Dan is traveling in his
> > >86FC
> > > > and
> > > > > the
> > > > > > engine began loosing power. he stopped and changed the Racor
> > > > filter.
> > > > > > Started and ran the same, no boost, no smoke, no power.
> > > > > > It has now stopped.
> > > > > > All suggestions appreciated!
> > > > > > Thanks
> > > > > > Jay Darst
> > > > > YAHOO! GROUPS LINKS
> > > > > a.. Visit your group "WanderlodgeForum" on the web.
> > > > > b.. To unsubscribe from this group, send an email to:
> > > > > WanderlodgeForum-unsubscribe@yahoogroups.com
> > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo!
> > >Terms
> > > > of Service.
> > > > > [Non-text portions of this message have been removed]
07-10-2005, 13:57
FC quit running
Following up on this old thread.
Changed the two foot piece of flexible fuel line that flows fuel TO
the cat located between the cat filter and the copper tubing coming
from the racor. Thinking that the age of the tubing with fuel
saturation may allow it to collapse. Went on a 500 mile trip this
weekend with no symptoms of fuel starvation or power loss.
I was having this problem for two or three months starting in August
03 and at that time did some maintenance procedures. The starvation
never reoccurred until last week.
I think/hope we fixed the right thing this time, but will wait two
years to conclude.
me five
the copper
problem.
run test
> probably tomorrow.
> >From: "Dan Carr"
work
warmed
fuel
been
> >Dan Carr
> >82PT40 6V92
> >Columbiana, OH
central
> >time.
lack of
> >fuel flow
facet
> >pusher
to take
> >racor
not
> >had this
> > > Thanks again.
> > > >From: "pattypape"
> > > >Jay.
will
idea to
thread on
to the
> > > >disconnected.
injectors, until
Cat
> > > >always starts.
> > > >Bill 88 FC
high
> > > >gear
delivery
> > > >(such
gears)is
> > > >being
However, as
level
> > > >reduces
down and
all the
> > > > > horses are back.
63mph
> > > >with
run, the
Where it
change. So he
as
> > > >filter.
maybe 2
Facet pump
> > > >and
BUT, NO
> > > >problems.
> > > > > The fuel is fresh
way, that
there done
> > > > > that.
clean the
> > > > > What else?
> > > > > Jay Darst
some days)
> > > > > 85PT40 ;~)
fuel
> > > >sol.on
fixed
> > > >it.
> > > > > Randy
> > > > > > From: samax8
watch water
water
> > > > > separator.
solved the
> > > > > problem.
> > > > > > Bill
> > > > > > 82FC33
in his
> > > >86FC
> > > > > and
> > > > > > the
the Racor
> > > > > filter.
power.
> > > > > > > It has now stopped.
> > > > > > > Thanks
> > > > > > > Jay Darst
> > > > > > YAHOO! GROUPS LINKS
to:
Yahoo!
> > > >Terms
> > > > > of Service.
