Refir LP and LP Heat Switch
11-10-2008, 06:31
Blue Book states:
"L.P. HEAT Switch - When in the ON position, 12v power is supplied to the L.P.G furnaces." I believe our 'Bird is working as BB designed.
On Mon, Nov 10, 2008 at 9:56 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
11-10-2008, 06:46
Curt,
Are we talking two different switches? It may be interpretation, but I think I agree with what your book says: 12V power is supplied. As I recall in my 83 PT, I could have power to the furnace igniters without having LP going to them if the LP master or the alarm under the dinette was off. On my 91, I don't have LP furnaces, but if either (or both) the LP master is off and the alarm is off, I do not get any LP to the stove or the frig, but I do have igniter power to them. Am I reading this one wrong?? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Blue Book states: > > "L.P. HEAT Switch - When in the ON position, 12v power is supplied to the > L.P.G furnaces." > > I believe our 'Bird is working as BB designed. > > > > On Mon, Nov 10, 2008 at 9:56 AM, mbulriss <mbulriss@...> wrote: > > > More than interesting; potentially dangerous? I thought that both the > > master LP switch and the gas alarm always had to be on for the LP to > > work on anything LP. Could PO have modified the frig? > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "Curt Sprenger" > > > > > > > > I just went out to the 'Bird. The LP dash switch is in the off > > position. > > > The frig. LP works in this off mode. Interesting. > > > > > > > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels > > > > > > > --- In > > WanderlodgeForum@yahoogroups.com > > > > > > "Scott Forman" > > > > <scottforman75@> wrote: > > > > > Ed Gardels 89sp > > > > Arlington Texas > > > > > > > > > > > > Scott.. I had the exact same problem in my 89sp, and your right, > > you > > > > hace to have the lp heat sw on > > > > > > > > > I have been having sporadic luck getting my refir to work on LP. > > > > This > > > > > evening, I have determined that it appears that it will only > > work > > > > on LP > > > > > when the "LP Heat" switch on the dash is in the on position. > > > > Anyone > > > > > have any opinion why this would be? One should have nothing to > > do > > > > with > > > > > the other. > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
11-10-2008, 06:52
MIke,
I'm not locating the documentation for the 12v Master Switch. I believe Bill Pape is right..the 12v Master Switch must be ON for propane to flow. On Mon, Nov 10, 2008 at 10:46 AM, mbulriss <"mbulriss@yahoo.com"> wrote:
11-10-2008, 06:54
My error. It's the ELECTRONIC 12v Master Switch that must be on, as Bill said.
On Mon, Nov 10, 2008 at 10:52 AM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
MIke, -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
11-10-2008, 07:26
Curt,
That's why I asked if I was talking about the right switch. LOL... It is so easy to talk in cross purposes on the different models. On the 91, I've got the 12V Electronic master, the LPG Master and the LP alarm to remember. I can guarantee you also that if you forget the 12V electronic master, the step doesn't go in! Among other things. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > My error. It's the ELECTRONIC 12v Master Switch that must be on, as Bill > said. > > On Mon, Nov 10, 2008 at 10:52 AM, Curt Sprenger > > > MIke, > > > > I'm not locating the documentation for the 12v Master Switch. I believe > > Bill Pape is right..the 12v Master Switch must be ON for propane to flow. > > > > On Mon, Nov 10, 2008 at 10:46 AM, mbulriss <mbulriss@...> wrote: > > > >> Curt, > >> > >> Are we talking two different switches? It may be interpretation, but > >> I think I agree with what your book says: 12V power is supplied. > >> > >> As I recall in my 83 PT, I could have power to the furnace igniters > >> without having LP going to them if the LP master or the alarm under > >> the dinette was off. On my 91, I don't have LP furnaces, but if either > >> (or both) the LP master is off and the alarm is off, I do not get any > >> LP to the stove or the frig, but I do have igniter power to them. > >> > >> Am I reading this one wrong?? > >> > >> > >> Mike Bulriss > >> 1991 WB40 "Texas Minivan" > >> San Antonio, TX > >> > >> --- In WanderlodgeForum@yahoogroups.com > >> "Curt Sprenger" > >> > >> > > >> > Blue Book states: > >> > > >> > "L.P. HEAT Switch - When in the ON position, 12v power is supplied > >> to the > >> > L.P.G furnaces." > >> > > >> > I believe our 'Bird is working as BB designed. > >> > > >> > > >> > > >> > On Mon, Nov 10, 2008 at 9:56 AM, mbulriss <mbulriss@> wrote: > >> > > >> > > More than interesting; potentially dangerous? I thought that > >> both the > >> > > master LP switch and the gas alarm always had to be on for the LP > >> to > >> > > work on anything LP. Could PO have modified the frig? > >> > > > >> > > Mike Bulriss > >> > > 1991 WB40 "Texas Minivan" > >> > > San Antonio, TX > >> > > > >> > > > >> > > --- In > >> WanderlodgeForum@yahoogroups.com > >> > >> > >> > > "Curt Sprenger" > >> > > > >> > > > > >> > > > I just went out to the 'Bird. The LP dash switch is in the off > >> > > position. > >> > > > The frig. LP works in this off mode. Interesting. > >> > > > > >> > > > > >> > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels wrote: > >> > > > > >> > > > > --- In > >> > > WanderlodgeForum@yahoogroups.com > >> > >> > > > >> > > > > "Scott Forman" > >> > > > > <scottforman75@> wrote: > >> > > > > > Ed Gardels 89sp > >> > > > > Arlington Texas > >> > > > > > >> > > > > > >> > > > > Scott.. I had the exact same problem in my 89sp, and your > >> right, > >> > > you > >> > > > > hace to have the lp heat sw on > >> > > > > > >> > > > > > I have been having sporadic luck getting my refir to work on > >> LP. > >> > > > > This > >> > > > > > evening, I have determined that it appears that it will only > >> > > work > >> > > > > on LP > >> > > > > > when the "LP Heat" switch on the dash is in the on position. > >> > > > > Anyone > >> > > > > > have any opinion why this would be? One should have nothing > >> to > >> > > do > >> > > > > with > >> > > > > > the other. > >> > > > > > > >> > > > > > Scott Forman > >> > > > > > 86 PT38 > >> > > > > > Memphis > >> > > > > > > >> > > > > > >> > > > > > >> > > > > > >> > > > > >> > > > > >> > > > > >> > > > -- > >> > > > Curt Sprenger > >> > > > 1987 PT38 8V92 "MacAttack Racing" > >> > > > Anaheim Hills, CA > >> > > > > >> > > > >> > > > >> > > > >> > > >> > > >> > > >> > -- > >> > Curt Sprenger > >> > 1987 PT38 8V92 "MacAttack Racing" > >> > Anaheim Hills, CA > >> > > >> > >> > >> > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
11-10-2008, 07:31
Don't forget the switch at the external LP filler neck, on my coach
it will override all LP systems. Because or the presence of an excess flow valve in the LPG tank outlet ( Safety Feature ), sometimes an appliance will not relight after a shutdown. . In this circumstance, wait five ( 5 ), minutes for LPG pressure to equalize before relighting, excerpt from owners manual. for those that have them Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > More than interesting; potentially dangerous? I thought that both the > master LP switch and the gas alarm always had to be on for the LP to > work on anything LP. Could PO have modified the frig? > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > I just went out to the 'Bird. The LP dash switch is in the off > position. > > The frig. LP works in this off mode. Interesting. > > > > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > "Scott Forman" > > > <scottforman75@> wrote: > > > > Ed Gardels 89sp > > > Arlington Texas > > > > > > > > > Scott.. I had the exact same problem in my 89sp, and your right, > you > > > hace to have the lp heat sw on > > > > > > > I have been having sporadic luck getting my refir to work on LP. > > > This > > > > evening, I have determined that it appears that it will only > work > > > on LP > > > > when the "LP Heat" switch on the dash is in the on position. > > > Anyone > > > > have any opinion why this would be? One should have nothing to > do > > > with > > > > the other. > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > |
11-10-2008, 07:35
I doubt that it has been modified. Mine works like Curt just described. So did my previous 81FC.
11-10-2008, 13:00
