Air leak
08-24-2007, 10:33
Post: #21
Air leak
I have an air leak in the valve, on top of the engine, that controls
the throttle. A few years back, I purchased a new one from or pals Stewart and Stevenson. Paid over a hundred bucks for that. Ralph told me that I can just get the O-ring. I presume that's all it needs. Does anyone have a parts source for a 25 cent O-ring vs the whole valve? This O-ring is a little different then the run of the mill ones. Might even have to pay a dollar for it. Thanks, Ernie- spewing lots of air 83PT40 in Montana |
08-24-2007, 10:57
Post: #22
Air leak
Ernie,
Bet our friends at Interstate Detroit have one. They are open until midnight tonight I think. Want to try them? If they have it, I can drop by & get a couple for us. Bet I need a new one too or a spare. Terry Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Ernest Ekberg wrote: > I have an air leak in the valve, on top of the engine, that controls > the throttle. A few years back, I purchased a new one from or pals > Stewart and Stevenson. Paid over a hundred bucks for that. Ralph told > me that I can just get the O-ring. I presume that's all it needs. Does > anyone have a parts source for a 25 cent O-ring vs the whole valve? > This O-ring is a little different then the run of the mill ones. Might > even have to pay a dollar for it. Thanks, Ernie- spewing lots of air > 83PT40 in Montana > > [Non-text portions of this message have been removed] |
08-24-2007, 11:46
Post: #23
Air leak
Ernie:
Try to get one from an outfit that does hydraulics. They usually have a good source of O-rings. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I have an air leak in the valve, on top of the engine, that controls > the throttle. A few years back, I purchased a new one from or pals > Stewart and Stevenson. Paid over a hundred bucks for that. Ralph told > me that I can just get the O-ring. I presume that's all it needs. Does > anyone have a parts source for a 25 cent O-ring vs the whole valve? > This O-ring is a little different then the run of the mill ones. Might > even have to pay a dollar for it. Thanks, Ernie- spewing lots of air > 83PT40 in Montana > |
08-24-2007, 11:52
Post: #24
Air leak
Find a hydraulic system shop,tractor cylinders and stuff like that, they should
have a nice selection of O-rings. MH ----- Original Message ----- From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 24, 2007 4:33 PM Subject: [WanderlodgeForum] Air leak I have an air leak in the valve, on top of the engine, that controls the throttle. A few years back, I purchased a new one from or pals Stewart and Stevenson. Paid over a hundred bucks for that. Ralph told me that I can just get the O-ring. I presume that's all it needs. Does anyone have a parts source for a 25 cent O-ring vs the whole valve? This O-ring is a little different then the run of the mill ones. Might even have to pay a dollar for it. Thanks, Ernie- spewing lots of air 83PT40 in Montana [Non-text portions of this message have been removed] |
11-03-2007, 03:01
Post: #25
Air leak
The suspension dump switches, below the ignition key leak a small
amount of air. Is there a way to seal where the 1/8th inch plastic line goes into the switch or is a new switch needed. Elmer 86 PT 38 |
11-03-2007, 04:52
Post: #26
Air leak
Elmer,
Are you referring to the Clippard "DC / pneumatic" switches; at least that is what is in our '87 PT38. I had to replace them due to leaks and causing issues with the suspension dumping. Click on this link to see a picture of what is installed in our coach. http://www.clippard.com/store/byo_electr...efault.asp . It's the first one with the yellow head. I can look up the part numbers if you like, or you may find them on the switches. On 11/3/07, ejohna2000 > > The suspension dump switches, below the ignition key leak a small > amount of air. Is there a way to seal where the 1/8th inch plastic line > goes into the switch or is a new switch needed. Elmer 86 PT 38 > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-03-2007, 05:21
Post: #27
Air leak
Elmer,
Here is a link to the exact Electronic Valves that are used in our coach. There are at least five of them. http://www.clippard.com/store/display_de...u=ET-3M-12 The picture shows 24V, the description shows 12V. It's the correct part number (ET-3M 12V) for our '87 PT38. On 11/3/07, Curt Sprenger > > Elmer, > > Are you referring to the Clippard "DC / pneumatic" switches; at least that > is what is in our '87 PT38. I had to replace them due to leaks and causing > issues with the suspension dumping. Click on this link to see a picture of > what is installed in our coach. > http://www.clippard.com/store/byo_electr...efault.asp . It's the first > one with the yellow head. I can look up the part numbers if you like, or you > may find them on the switches. > > > On 11/3/07, ejohna2000 > > > > The suspension dump switches, below the ignition key leak a small > > amount of air. Is there a way to seal where the 1/8th inch plastic line > > goes into the switch or is a new switch needed. Elmer 86 PT 38 > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-04-2007, 08:00
Post: #28
Air leak
My coach had the same problem. Upon removing the switches, you could
see the tiny o rings were falling apart and pieces had stuck in the exhaust hole. These are regular truck dump switches and are easy to come by. Biggest problems was they are bigger than the old ones and had to turn them in their location to make them fit..small price to pay. Bob Lawrence 84 PT 36 On the road fulltiming in Clarkston, Wa. > The suspension dump switches, below the ignition key leak a small > amount of air. Is there a way to seal where the 1/8th inch plastic line > goes into the switch or is a new switch needed. Elmer 86 PT 38 > |
09-01-2009, 08:26
Post: #29
Air leak
Hi Guys
I found were the 1/4" copper tube went to & what was leaking. It is the discharge for the ZF retarder leaver on the left side of the dash. Any one know if it can be rebuilt or where to buy a new one? Don Spithaler 89 SP 36' Butler, PA |
