Fire Hazard
07-01-2010, 09:19
Fire Hazard
Tks Project Ken Doyle ConServe PO Box 35245 Richmond, VA 23235 direct: 301-908-5735 fax: 804-725-2982 From: Ken, not the fresh water tank in your Coach. You have a small space heater attached to a gray square D thermostat control Safe travels, Ralph Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T From: "Ken Doyle" Sender: WanderlodgeForum@yahoogroups.com Date: Thu, 1 Jul 2010 17:07:26 -0400 To: ReplyTo: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Fire Hazard Ernie, Are heaters used with the 84pt40? Ken Doyle ConServe 100 Pine View Dr Mobjack, VA 23056 h: 804-725-3132 f: 804-725-2982 c: 301-908-5735 From:
After removing a fresh water tank on an SP, we found that the freeze protection mat had scorched the bottom of the tank and the plywood floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that has this setup should absolutely discontinue using it. I will post a few photos in the photo section and will title it fire hazard. Ernie-83PT40 in Texas |
07-01-2010, 09:21
Fire Hazard
Tks Project Ken Doyle ConServe PO Box 35245 Richmond, VA 23235 direct: 301-908-5735 fax: 804-725-2982 From: Ken, We had those vertical electric heaters on our '84 FC. Brad (former LXi) "bbartonwx@hotmail.com" http://www.bradsweather.com To: WanderlodgeForum@yahoogroups.com Ernie, Are heaters used with the Ken Doyle ConServe 100 Pine Mobjack, VA h: f: c: From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] After removing a fresh water tank on an SP, we found that The New Busy is not the old busy. Search, chat and e-mail |
07-01-2010, 09:50
Fire Hazard
