New replacement Rear camera- 450 and 380?
07-28-2014, 12:02
Hi, I have replaced the rear camera on the 450 using the same cable and Panasonic monitor. The original camera was a MITO ecx 100. A double camera with B/W and colour. It is no longer made. I spoke with a very helpful rep at Mito corp who suggested using an adapter that they have available with the Mito CM 32 http://mito-oem.com/product.php?id=CM32AH The adapter requires 4 soldered connections that can be done on a bench. Then a simple plug in. I mounted the camera behind the glass but the IR caused double reflection so I had to mount it outside, drilling a 5/8 hole in the FG under the old glass. Drill the hole off centre to give the wire some room to allow tipping. The unit comes with a grommet. It was made for metal but it works with touch of adhesive -- unlikely that it would come out anyway. Cost about $140 Picture of camera installed. Contact: Travis Monroe Technical Service Representative 1-888-433-6486 EXT. 271 (Phone) (574) 522-5480(Fax) (574) 970-0082 (Marine Fax Line) Tmonroe@MITOcorp.com (E-Mail) MITO Corporation Ross MacKillop Wiarton Ontario 2006 450 Lxi |
07-28-2014, 19:01
RE: New replacement Rear camera- 450 and 380?
Ross do you have the side mount cameras? I have a nice blind spot I would like to eliminate.
07-29-2014, 11:08
Ernie,
The 450 came with side cameras and a front camera.(good for driving with the front blinds down ) There is a dash switch to change cameras. There is also the capability to view through all the cameras while in bed (on the TV) The switch to change cameras is above the headboard. The side cameras activate with the turn signals. There appear to be kits available, but wiring may be a PIA. Mito has a couple with 3, 4 camera inputs and "Trigger" wiring. Best one appears to be this--4 views at once would be neat for security/curiousity. http://mito-oem.com/product.php?id=CM709M2 Ross (07-28-2014 19:01)ernie ekberg Wrote: Ross do you have the side mount cameras? I have a nice blind spot I would like to eliminate. Ross MacKillop Wiarton Ontario 2006 450 Lxi |
07-30-2014, 18:15
(07-28-2014 19:01)ernie ekberg Wrote: Ross do you have the side mount cameras? I have a nice blind spot I would like to eliminate. He probably does. I have them and also had aftermarkets ones installed on Pretty Penny. They have saved me embarrassment more than once. I wish I could take them to social events so they can save me there, too. Tommy "2 Shoes" McCarthy 2006 M450XLI "GoneAway" Former owner 1995 PT42 WB "Pretty Penny" Gardnerville, NV Near South Lake Tahoe |
07-30-2014, 18:56
Ross- do they sell to dealers or public. I see nothing on their website that states that. Thanks
07-30-2014, 21:18
I ordered directly form Travis.A very helpful tech. I suggest--- email to him or call if you need help.
He added the adapter to my order Ross (07-30-2014 18:56)ernie ekberg Wrote: Ross- do they sell to dealers or public. I see nothing on their website that states that. Thanks Ross MacKillop Wiarton Ontario 2006 450 Lxi |
07-31-2014, 08:02
I'm not familiar with Travis
07-31-2014, 09:21
Sorry, I was referring back to original post. Travis is the contact for MITO Corp.
(07-31-2014 08:02)ernie ekberg Wrote: I'm not familiar with Travis Ross MacKillop Wiarton Ontario 2006 450 Lxi |
08-01-2014, 08:06
thanks
08-06-2014, 01:19
Thanks Guys.
I ordered the system today with the backup and side cameras. My old OEM black and white camera finally expired. I will have to pull the new cable all the way to the front. Dealt with Tim Suetkamp at extension 250. . |
