90WLSP36 Smoke and heat
11-21-2005, 06:40
Thanks to all who responded. One thing I notice is that there is no
oil smoke after the engine warms up. Doesn't this say that the problem is not the rings? Chuck Harrison Akron, Ohio 90 WLSP |
11-21-2005, 06:59
On our 88 FC the only switch is a circuit breaker in the 110 AC
Load center panel. It is labeled Block Heater. Some BB's have an on/off switch in the co-pilot feet seat area on the floor. You probably know to plug into 110 AC shore power. Four hours is probably sufficient time. Many school district busses are plugged and warmed overnight Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Thanks George, > I tried an experiment, I kept the bird in our heated warehouse > over the weekend and when I started it this morning there was little > or no oil smoke. By the way, how do you turn on the engine > preheat? > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > <mrdonut12@y...> wrote: > > > > > > > > Chuck, > > Although the smoke is getting worse, the weather is also > getting > > colder. It may just be cold weather that's causing the smoke. > > Last winter, mine smoked so bad when started on a very cold > day > > that it appeared someone should call the Fire Dept. ;o) > > I found my engine heater had quit working. I went to NAPA and > > bought a 2,000 watt engine heater. > > If I pre-heat the engine, it barely smokes at all, but if the > > engine is bone-cold when I start it, it can produce significant > smoke. > > The 3208 has no glow plugs, so it's extremely inefficient on a > > cold start and that's where the smoke comes from. > > Pre-heat your engine before starting and if that reduces the > > smoke significantly, it may not even be broken, just a 3208. > > Regarding the engine temp, you need to go to a Cat dealer and > get > > the "thermostat kit" so you have good quality thermostats (it uses > 2). > > Running the engine below operating temp isn't good for the > engine. > > If fact, I believe in changing thermostats about every 3 years as a > > maintenance item. A bad thermostat can have a significant impact > on > > an engine and I don't like risk. Better safe than sorry. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > Just recently my bird began to blow blue oil smoke when it was > cold. > > > This symptom has gradually gotten worse over the last 3 months. > > > After warmup the smoke disappeared (after 10 min or so). I took > it > > > to the local Cat dealer who discovered that the turbo was shot. > > > He replaced the turbo ($4000.00 +) and the oil smoke is worse > than > > > before, what's more, the engine will not heat to above 160 deg. > > > whereas before it ran at 190 deg. The dealer says I have to run > it > > > hard to clean the engine out but I have to get the engine temp > up. > > > The oil temp also does not go up over 170 deg. Does this sound > like > > > symptoms of a stuck thermostat? If so, how hard is it to > replace and > > > what would cause the excessive oil smoke? > > > > > > Thanks, > > > Chuck Harrison > > > Akron, Ohio > > > 90 WL SP36 > > > > > > |
11-21-2005, 10:02
Chuck My 89 SP 36' has the breaker in the box as you come in the door.
There is no switch for it. You have to turn the breaker on for mine. Don 89 SP 36' Butler, PA Thanks George, I tried an experiment, I kept the bird in our heated warehouse over the weekend and when I started it this morning there was little or no oil smoke. By the way, how do you turn on the engine preheat? --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > > > > Chuck, > Although the smoke is getting worse, the weather is also getting > colder. It may just be cold weather that's causing the smoke. > Last winter, mine smoked so bad when started on a very cold day > that it appeared someone should call the Fire Dept. ;o) > I found my engine heater had quit working. I went to NAPA and > bought a 2,000 watt engine heater. > If I pre-heat the engine, it barely smokes at all, but if the > engine is bone-cold when I start it, it can produce significant smoke. > The 3208 has no glow plugs, so it's extremely inefficient on a > cold start and that's where the smoke comes from. > Pre-heat your engine before starting and if that reduces the > smoke significantly, it may not even be broken, just a 3208. > Regarding the engine temp, you need to go to a Cat dealer and get > the "thermostat kit" so you have good quality thermostats (it uses 2). > Running the engine below operating temp isn't good for the engine. > If fact, I believe in changing thermostats about every 3 years as a > maintenance item. A bad thermostat can have a significant impact on > an engine and I don't like risk. Better safe than sorry. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > Just recently my bird began to blow blue oil smoke when it was cold. > > This symptom has gradually gotten worse over the last 3 months. > > After warmup the smoke disappeared (after 10 min or so). I took it > > to the local Cat dealer who discovered that the turbo was shot. > > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > > before, what's more, the engine will not heat to above 160 deg. > > whereas before it ran at 190 deg. The dealer says I have to run it > > hard to clean the engine out but I have to get the engine temp up. > > The oil temp also does not go up over 170 deg. Does this sound like > > symptoms of a stuck thermostat? If so, how hard is it to replace and [Non-text portions of this message have been removed] |
11-22-2005, 01:54
> The results of that experiment would lead me to believe the smoke isn't oil smoke at all, just an extremely inefficient diesel engine. The smoke most likely has a very strong diesel smell to it. Oil smoke would smell more like burning oil (duh). ;o) My results are the same--cold engine, lots of smoke, warm engine, very little smoke on startup. Happy I could help. George Witt 81 FC 35 Lincoln, Nebraska > Thanks George, > I tried an experiment, I kept the bird in our heated warehouse > over the weekend and when I started it this morning there was little > or no oil smoke. By the way, how do you turn on the engine > preheat? > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > <mrdonut12@y...> wrote: > > > > > > > > Chuck, > > Although the smoke is getting worse, the weather is also > getting > > colder. It may just be cold weather that's causing the smoke. > > Last winter, mine smoked so bad when started on a very cold > day > > that it appeared someone should call the Fire Dept. ;o) > > I found my engine heater had quit working. I went to NAPA and > > bought a 2,000 watt engine heater. > > If I pre-heat the engine, it barely smokes at all, but if the > > engine is bone-cold when I start it, it can produce significant > smoke. > > The 3208 has no glow plugs, so it's extremely inefficient on a > > cold start and that's where the smoke comes from. > > Pre-heat your engine before starting and if that reduces the > > smoke significantly, it may not even be broken, just a 3208. > > Regarding the engine temp, you need to go to a Cat dealer and > get > > the "thermostat kit" so you have good quality thermostats (it uses > 2). > > Running the engine below operating temp isn't good for the > engine. > > If fact, I believe in changing thermostats about every 3 years as a > > maintenance item. A bad thermostat can have a significant impact > on > > an engine and I don't like risk. Better safe than sorry. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > Just recently my bird began to blow blue oil smoke when it was > cold. > > > This symptom has gradually gotten worse over the last 3 months. > > > After warmup the smoke disappeared (after 10 min or so). I took > it > > > to the local Cat dealer who discovered that the turbo was shot. > > > He replaced the turbo ($4000.00 +) and the oil smoke is worse > than > > > before, what's more, the engine will not heat to above 160 deg. > > > whereas before it ran at 190 deg. The dealer says I have to run > it > > > hard to clean the engine out but I have to get the engine temp > up. > > > The oil temp also does not go up over 170 deg. Does this sound > like > > > symptoms of a stuck thermostat? If so, how hard is it to > replace and > > > what would cause the excessive oil smoke? > > > > > > Thanks, > > > Chuck Harrison > > > Akron, Ohio > > > 90 WL SP36 > > > > > > |
11-22-2005, 04:33
Rings, Ipump, Inozzle, Condensation, They all contribute to the
smoke. Diesel fuel is oil and it will have a oil smell but the prob is not burning oil it is unburned fuel oil. Modern diesels have computers to control the emissions but those engines would smoke untill warm up if the computers did not take actions to prevent this. If you notice diesel tractors on construction sites that do not have mandatory computer controlled emissions, they smoke alot untill warm. Piston rings are not the correct size untill the heat goes up to Mfg thermostat setting. That is why it is not a good idea to replace the Tstat with a colder one. The viscosity of fuel oil and lube oil is thicker and spray patterns are not correct untill the temp is up. Running the cold engine under a load causes the pistons to run ascew and ill lubed. If after warm up a emissions screening shows unburned fuel it may be time to have the injectors cleaned or the rack adjusted on the pump. You see more smoke for two reasons, 1- now you look back in horror 2- modern diesels dont smoke much and you compare. My advise is 'Dont look back' and have a cat dealer gyro test it warm befor you spend any money on needless repair. Gregory O'Connor 94pt40 (2- 1985 3208 dump trucks) --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > The results of that experiment would lead me to believe the smoke > isn't oil smoke at all, just an extremely inefficient diesel engine. > The smoke most likely has a very strong diesel smell to it. Oil smoke > would smell more like burning oil (duh). ;o) > My results are the same--cold engine, lots of smoke, warm engine, > very little smoke on startup. > Happy I could help. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > > > Thanks George, > > I tried an experiment, I kept the bird in our heated warehouse > > over the weekend and when I started it this morning there was little > > or no oil smoke. By the way, how do you turn on the engine > > preheat? > > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > > <mrdonut12@y...> wrote: > > > > > > > > > > > > Chuck, > > > Although the smoke is getting worse, the weather is also > > getting > > > colder. It may just be cold weather that's causing the smoke. > > > Last winter, mine smoked so bad when started on a very cold > > day > > > that it appeared someone should call the Fire Dept. ;o) > > > I found my engine heater had quit working. I went to NAPA and > > > bought a 2,000 watt engine heater. > > > If I pre-heat the engine, it barely smokes at all, but if the > > > engine is bone-cold when I start it, it can produce significant > > smoke. > > > The 3208 has no glow plugs, so it's extremely inefficient on a > > > cold start and that's where the smoke comes from. > > > Pre-heat your engine before starting and if that reduces the > > > smoke significantly, it may not even be broken, just a 3208. > > > Regarding the engine temp, you need to go to a Cat dealer and > > get > > > the "thermostat kit" so you have good quality thermostats (it uses > > 2). > > > Running the engine below operating temp isn't good for the > > engine. > > > If fact, I believe in changing thermostats about every 3 years as a > > > maintenance item. A bad thermostat can have a significant impact > > on > > > an engine and I don't like risk. Better safe than sorry. > > > > > > George Witt > > > 81 FC 35 > > > Lincoln, Nebraska > > > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > > > > Just recently my bird began to blow blue oil smoke when it was > > cold. > > > > This symptom has gradually gotten worse over the last 3 months. > > > > After warmup the smoke disappeared (after 10 min or so). I took > > it > > > > to the local Cat dealer who discovered that the turbo was shot. > > > > He replaced the turbo ($4000.00 +) and the oil smoke is worse > > than > > > > before, what's more, the engine will not heat to above 160 deg. > > > > whereas before it ran at 190 deg. The dealer says I have to run > > it > > > > hard to clean the engine out but I have to get the engine temp > > up. > > > > The oil temp also does not go up over 170 deg. Does this sound > > like > > > > symptoms of a stuck thermostat? If so, how hard is it to > > replace and > > > > what would cause the excessive oil smoke? > > > > > > > > Thanks, > > > > Chuck Harrison > > > > Akron, Ohio > > > > 90 WL SP36 > > > > > > > > > > |
11-22-2005, 10:41
I apologize for being late with this suggestion,
My SP36 smoked early in the AM and when it was cold, I took it to CAT dealer in Phoenix and had them retime the injector pump taking care of the smoke. Really!! Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
