A long afternoon
02-28-2010, 16:19
A long afternoon
Bob,
Good to have you back on the forum. Thanks for the offer to try the 170 t-stats. When you changed the t-stats, did you also change the alarmstat that controls the fan? I am curious and do not understand why the fan cycled more often. If you put in lower t-stats without changing the alarmstat, I would have thought that it would have cycled less often. What am I missing? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Robert Johannesen > > I dropped my thermoststsà to 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > à > > > > ________________________________ > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Sun, February 28, 2010 1:58:50 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > à > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
02-28-2010, 16:42
A long afternoon
No, I didn't change the alarmstat - that may have been the cause.
I also wanted the engine to run cooler, but after talking to Detroit, they really wanted it at the higher temp. I wanted to put an oil cooler on it also, but they designed the water/oil heat exchanger on the left side of the block to keep both temps up higher for the 2 cycle. After I replaced the radiator core the engine runs so much better but still at the factory settings. Next is replacing the engine soundproofing.
Since I last saw Ya'll, I went back to work for almost 3 years, but that is a six pack story! We plan to travel about 3 weeks each quater now that both of us have retired (again). And we should be able to make some Lone Star Rallies between Grandparent duties and the BB fix it list!
From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Sun, February 28, 2010 10:19:36 PM Subject: [WanderlodgeForum] Re: A long afternoon Bob, Good to have you back on the forum. Thanks for the offer to try the 170 t-stats. When you changed the t-stats, did you also change the alarmstat that controls the fan? I am curious and do not understand why the fan cycled more often. If you put in lower t-stats without changing the alarmstat, I would have thought that it would have cycled less often. What am I missing? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In "WanderlodgeForum%40yahoogroups.com", Robert Johannesen > > I dropped my thermoststsÃâto 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > Ãâ > > > > ____________ _________ _________ __ > From: ronmarabito2002 > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sun, February 28, 2010 1:58:50 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > Ãâ > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
03-01-2010, 00:25
A long afternoon
My 1983 PT35, 6V92T has a small leak at the coolant reservoir box Bill 1983, PT 35 WL, 6V 92 T DD PC FL From: WanderlodgeForum@yahoogroups.com No, I didn't change the I also wanted the engine to Since I last saw Ya'll, I From: mbulriss Bob, Good to have you back on the forum. Thanks for the offer to try the 170 t-stats. When you changed the t-stats, did you also change the alarmstat that controls the fan? I am curious and do not understand why the fan cycled more often. If you put in lower t-stats without changing the alarmstat, I would have thought that it would have cycled less often. What am I missing? Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > I dropped my thermoststsÃâto 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > Ãâ > > > > ____________ _________ _________ __ > From: ronmarabito2002 > To: WanderlodgeForum@ yahoogroups. com > Sent: Sun, February 28, 2010 1:58:50 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > Ãâ > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
03-01-2010, 03:44
A long afternoon
Hi Bob,
Yes, one alternator runs the whole thing very well. Plus it's a 30 minute fix to replace number 2 down behind the bumper, versus hours of work to replace number 1 under the bed. I just kind of like things they way they were built. I wonder why BB thought too small a cable was killing alt 1? Maybe one of our electrical gurus can explain it to us. I thought it might be the heat up over that engine. I note that they installed an air cooling tube on the lower one behind the bumper, but none on alt 1. In my case, it was the voltage regulator that went away and started charging at 16.5 volts. That drove all the gauges crazy! Send me a picture of your Bird in that great parking spot against the Gulf, for Bird of the Week, so the rest of us can live vicariously! Wishing we were there. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "contrail Bob" > > Hi Mike > I replaced the #1 Alt. twice on my 93. After the second time It failed again and I just took it off and left it off. I never had any problem's with the # 2 and it charged everything just fine. Talking to BB sometime later I was told that the cable's were too small and they thought that was the problem with premature failure of #1?????? > Bob 99LX SK..SPI till 20Mar. > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
03-05-2010, 10:34
A long afternoon
I am interested in this engine thermostat phenomenom. I messed with my cooling
system for months and found a combination that works well for me. The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. --- In WanderlodgeForum@yahoogroups.com, Robert Johannesen > > I dropped my thermoststsà to 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > à > > > > ________________________________ > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Sun, February 28, 2010 1:58:50 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > à > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
03-05-2010, 17:04
A long afternoon
Leroy, I would like to know also! Thanks for your response.
Where is the alarmstat for the fan normally located? I will check and see what its setting is. My goal was to have all the engine temps run lower. My oil temp is now about 230 constantly.
I will go back an read my maintenance log to refresh my memory, because it has been about 10 years since I tried the change. I remember being very disappointed. I know I didn't change my alarmstat for the fan because I didn't realize I had one. It is probably in the hydraulic circuit between the pump and the valve that opens the flow and maybe I can read the setting on the device itself.
I will go back and research the system (I think I have the applicable BB prints)again because I do want it to run cooler (Oil temp and water temp) if possible. I am also not opposed to designing an in line oil cooler.Having it closer to the water temp is OK with me. My heat exchanger for the Oil and water is so close to the frame on the left side of the block that it cannot be removed to inspect or examine it.
I may set up and try my alarmstat the way you did sinceyou seem like it that way and your temps are very reasonable. Will let ya'll know. Going back to VaBch next month so I may get it done and check it before then.
Thanks, Bob J.
From: Leroy To: WanderlodgeForum@yahoogroups.com Sent: Fri, March 5, 2010 4:34:57 PM Subject: [WanderlodgeForum] Re: A long afternoon I am interested in this engine thermostat phenomenom. I messed with my cooling system for months and found a combination that works well for me. The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. --- In "WanderlodgeForum%40yahoogroups.com", Robert Johannesen > > I dropped my thermoststsÃâto 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > Ãâ > > > > ____________ _________ _________ __ > From: ronmarabito2002 > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sun, February 28, 2010 1:58:50 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > Ãâ > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > Long day..... having fun. > > > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > |
03-06-2010, 02:08
A long afternoon
The Alarmstat is located on the left hand side of the water pump in the water
jacket of the engine on my coach. It is a bulb looking instrument with two wires attached to it. The original had screws attaching the wires attached to it. The replacement has slide on connections. If it has not been painted it may have the name Kysor on it. The temp range is stamped on the hex part of the instrument. BB part number for the 190 version which means nothing except for reference purposes is 1594951. You can see one at http://www.medallionis.com under switches, senders and sensors, pn 1002-07478-30. The NC version. As for oil temp mine runs in the 215- 230 range but is affected by OAT, radiator water temp and road speed. I have messed with that also. My understanding is there are two Detroit oil coolers which bolt onto the left side of the engine. They have a different number of cooling plates. It is cooled by the radiator water. So reduction of the average water temp reduces oil temp but only by about 5-8%. In winter my oil temp will run about 215 at 62mph. In summer is runs 230 at the same speed simply because the average running water temp increases. The only way to reduce oil temp would be to add an oil cooler. My conclusion on that issue has been I have not done it. If I did, I believe the way to do it would be to somehow have the pick up on the pressure side off the main oil filter cycling oil to a separate air cooled cooler and dump the cooled oil into the pan which would then reduce overall pan oil temp before it is reintroduced onto the main oil pump pick up. Or have a larger engine oil cooler which is water cooled built. Probably cost prohibitive. I have had lengthy discussions with BB and Detroit. Detroit did not spec the Alarmstat in BB engines. BB engineers did and I was never able to determine why it was installed in the first place but speculate it was intended to have the fan idle to prevent dust from blowing all over creation, including being inducted into the fins of the radiator while operating off the highway at slower speeds. As a practical matter, the Alarmstat forces temps to run higher than I like. While it is important to heat up the oil to remove moisture this is accomplished at 180-200 or 230. In aircraft, oil temp typically runs 180-190 and all is well. So, in the summer I personally run my coach on fan override after I get on the highway and that keeps temps at a solid 190 on the water and around 220-230 on the oil. I simply shut off the fan override before leaving the highway and let the alarmstat control things them. In winter I allow the Alarmstat to do its thing. I know, the fan supposedly robs horsepower. I have not been able to prove that either using the computer. Besides, I have a solid argument regarding horsepower and that fan which I will not go into indepth here. It is simple. On the flat you are not using the HP. Climbing the mountain it is not available because the fan is on high: That assumes the HP rob was there in the first place. Hope this gives you some insight into the ops. --- In WanderlodgeForum@yahoogroups.com, Robert Johannesen > > à à à à Leroy, I would like to know also! Thanks for your response. > > à à à à Where is the alarmstat for the fan normally located? I will check and see what its setting is. My goal was to have all theà engine temps run lower. My oil temp is now about 230 constantly. > à à à à I will go back an read my maintenance log to refresh my memory, because it has been about 10 years since I tried the change. I remember being very disappointed. I know I didn't change my alarmstat for the fan because I didn't realize I had one. It is probably in the hydraulic circuit between the pump and the valve that opens the flow and maybe I can read the setting on the device itself. > à à à à I will go back and research the system (I think I have the applicable BB prints)à again because I do want it to run cooler (Oil temp and water temp) if possible. I am also not opposed to designing an in line oil cooler.à Having it closer to the water temp is OK with me. My heat exchanger for the Oil and water is so close to the frame on the left side of the block that it cannot be removed to inspect or examine it. > à à à à à I may set up and try my alarmstat the way you did sinceà you seem like it that way and your temps are very reasonable. > à à à à Will let ya'll know. Going back to VaBch next month so I may get it done and check it before then. > Thanks, Bob J. > > > > ________________________________ > From: Leroy > To: WanderlodgeForum@yahoogroups.com > Sent: Fri, March 5, 2010 4:34:57 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > à > I am interested in this engine thermostat phenomenom. I messed with my cooling system for months and found a combination that works well for me. > The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. > I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > I dropped my thermoststsÃâà to 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > > > Ãâà > > > > > > > > ____________ _________ _________ __ > > From: ronmarabito2002 > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Sun, February 28, 2010 1:58:50 PM > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > Ãâà > > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > > > Long day..... having fun. > > > > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > |
03-06-2010, 04:21
A long afternoon
Thanks, Leroy - sounds like we have gone through the same thought processes. I will check it soon. As an aviator myself, 230 degrees of oil temp bothers me!
Bob J
From: Leroy To: WanderlodgeForum@yahoogroups.com Sent: Sat, March 6, 2010 8:08:21 AM Subject: [WanderlodgeForum] Re: A long afternoon The Alarmstat is located on the left hand side of the water pump in the water jacket of the engine on my coach. It is a bulb looking instrument with two wires attached to it. The original had screws attaching the wires attached to it. The replacement has slide on connections. If it has not been painted it may have the name Kysor on it. The temp range is stamped on the hex part of the instrument. BB part number for the 190 version which means nothing except for reference purposes is 1594951. You can see one at http://www.medallionis. com under switches, senders and sensors, pn 1002-07478-30. The NC version. As for oil temp mine runs in the 215- 230 range but is affected by OAT, radiator water temp and road speed. I have messed with that also. My understanding is there are two Detroit oil coolers which bolt onto the left side of the engine. They have a different number of cooling plates. It is cooled by the radiator water. So reduction of the average water temp reduces oil temp but only by about 5-8%. In winter my oil temp will run about 215 at 62mph. In summer is runs 230 at the same speed simply because the average running water temp increases. The only way to reduce oil temp would be to add an oil cooler. My conclusion on that issue has been I have not done it. If I did, I believe the way to do it would be to somehow have the pick up on the pressure side off the main oil filter cycling oil to a separate air cooled cooler and dump the cooled oil into the pan which would then reduce overall pan oil temp before it is reintroduced onto the main oil pump pick up. Or have a larger engine oil cooler which is water cooled built. Probably cost prohibitive. I have had lengthy discussions with BB and Detroit. Detroit did not spec the Alarmstat in BB engines. BB engineers did and I was never able to determine why it was installed in the first place but speculate it was intended to have the fan idle to prevent dust from blowing all over creation, including being inducted into the fins of the radiator while operating off the highway at slower speeds. As a practical matter, the Alarmstat forces temps to run higher than I like. While it is important to heat up the oil to remove moisture this is accomplished at 180-200 or 230. In aircraft, oil temp typically runs 180-190 and all is well. So, in the summer I personally run my coach on fan override after I get on the highway and that keeps temps at a solid 190 on the water and around 220-230 on the oil. I simply shut off the fan override before leaving the highway and let the alarmstat control things them. In winter I allow the Alarmstat to do its thing. I know, the fan supposedly robs horsepower. I have not been able to prove that either using the computer. Besides, I have a solid argument regarding horsepower and that fan which I will not go into indepth here. It is simple. On the flat you are not using the HP. Climbing the mountain it is not available because the fan is on high: That assumes the HP rob was there in the first place. Hope this gives you some insight into the ops. --- In "WanderlodgeForum%40yahoogroups.com", Robert Johannesen > > ÃâÃâÃâÃâ Leroy, I would like to know also! Thanks for your response. > > ÃâÃâÃâÃâ Where is the alarmstat for the fan normally located? I will check and see what its setting is. My goal was to have all theÃâ engine temps run lower. My oil temp is now about 230 constantly. > ÃâÃâÃâÃâ I will go back an read my maintenance log to refresh my memory, because it has been about 10 years since I tried the change. I remember being very disappointed. I know I didn't change my alarmstat for the fan because I didn't realize I had one. It is probably in the hydraulic circuit between the pump and the valve that opens the flow and maybe I can read the setting on the device itself. > ÃâÃâÃâÃâ I will go back and research the system (I think I have the applicable BB prints)Ãâagain because I do want it to run cooler (Oil temp and water temp) if possible. I am also not opposed to designing an in line oil cooler.ÃâHaving it closer to the water temp is OK with me. My heat exchanger for the Oil and water is so close to the frame on the left side of the block that it cannot be removed to inspect or examine it. > ÃâÃâÃâÃâÃâ I may set up and try my alarmstat the way you did sinceÃâyou seem like it that way and your temps are very reasonable. > ÃâÃâÃâÃâ Will let ya'll know. Going back to VaBch next month so I may get it done and check it before then. > Thanks, Bob J. > > > > ____________ _________ _________ __ > From: Leroy > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Fri, March 5, 2010 4:34:57 PM > Subject: [WanderlodgeForum] Re: A long afternoon > > Ãâ > I am interested in this engine thermostat phenomenom. I messed with my cooling system for months and found a combination that works well for me. > The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. > I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > I dropped my thermoststs̢̮â¬Å¡Ãâto 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > > > ̢̮â¬Å¡Ãâ > > > > > > > > ____________ _________ _________ __ > > From: ronmarabito2002 > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Sun, February 28, 2010 1:58:50 PM > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > ̢̮â¬Å¡Ãâ > > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > > > Long day..... having fun. > > > > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > |
03-06-2010, 06:08
A long afternoon
Bob: My oil temperature runs there all the time.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Robert Johannesen > > Thanks, Leroy - sounds like we have gone through the same thought processes. I will check it soon. As an aviator myself, 230 degrees of oil temp bothers me! > Bob J > > > > > ________________________________ > From: Leroy > To: WanderlodgeForum@yahoogroups.com > Sent: Sat, March 6, 2010 8:08:21 AM > Subject: [WanderlodgeForum] Re: A long afternoon > > à > The Alarmstat is located on the left hand side of the water pump in the water jacket of the engine on my coach. It is a bulb looking instrument with two wires attached to it. The original had screws attaching the wires attached to it. The replacement has slide on connections. If it has not been painted it may have the name Kysor on it. The temp range is stamped on the hex part of the instrument. BB part number for the 190 version which means nothing except for reference purposes is 1594951. You can see one at http://www.medallionis. com under switches, senders and sensors, pn 1002-07478-30. The NC version. > > As for oil temp mine runs in the 215- 230 range but is affected by OAT, radiator water temp and road speed. I have messed with that also. My understanding is there are two Detroit oil coolers which bolt onto the left side of the engine. They have a different number of cooling plates. It is cooled by the radiator water. So reduction of the average water temp reduces oil temp but only by about 5-8%. In winter my oil temp will run about 215 at 62mph. In summer is runs 230 at the same speed simply because the average running water temp increases. The only way to reduce oil temp would be to add an oil cooler. My conclusion on that issue has been I have not done it. If I did, I believe the way to do it would be to somehow have the pick up on the pressure side off the main oil filter cycling oil to a separate air cooled cooler and dump the cooled oil into the pan which would then reduce overall pan oil temp before it is reintroduced onto the main oil pump pick > up. Or have a larger engine oil cooler which is water cooled built. Probably cost prohibitive. > > I have had lengthy discussions with BB and Detroit. Detroit did not spec the Alarmstat in BB engines. BB engineers did and I was never able to determine why it was installed in the first place but speculate it was intended to have the fan idle to prevent dust from blowing all over creation, including being inducted into the fins of the radiator while operating off the highway at slower speeds. > > As a practical matter, the Alarmstat forces temps to run higher than I like. While it is important to heat up the oil to remove moisture this is accomplished at 180-200 or 230. In aircraft, oil temp typically runs 180-190 and all is well. > > So, in the summer I personally run my coach on fan override after I get on the highway and that keeps temps at a solid 190 on the water and around 220-230 on the oil. I simply shut off the fan override before leaving the highway and let the alarmstat control things them. In winter I allow the Alarmstat to do its thing. > > I know, the fan supposedly robs horsepower. I have not been able to prove that either using the computer. Besides, I have a solid argument regarding horsepower and that fan which I will not go into indepth here. It is simple. On the flat you are not using the HP. Climbing the mountain it is not available because the fan is on high: That assumes the HP rob was there in the first place. > > Hope this gives you some insight into the ops. > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > Ãâà Ãâà Ãâà Ãâà Leroy, I would like to know also! Thanks for your response. > > > > Ãâà Ãâà Ãâà Ãâà Where is the alarmstat for the fan normally located? I will check and see what its setting is. My goal was to have all theÃâà engine temps run lower. My oil temp is now about 230 constantly. > > Ãâà Ãâà Ãâà Ãâà I will go back an read my maintenance log to refresh my memory, because it has been about 10 years since I tried the change. I remember being very disappointed. I know I didn't change my alarmstat for the fan because I didn't realize I had one. It is probably in the hydraulic circuit between the pump and the valve that opens the flow and maybe I can read the setting on the device itself. > > Ãâà Ãâà Ãâà Ãâà I will go back and research the system (I think I have the applicable BB prints)Ãâà again because I do want it to run cooler (Oil temp and water temp) if possible. I am also not opposed to designing an in line oil cooler.Ãâà Having it closer to the water temp is OK with me. My heat exchanger for the Oil and water is so close to the frame on the left side of the block that it cannot be removed to inspect or examine it. > > Ãâà Ãâà Ãâà Ãâà Ãâà I may set up and try my alarmstat the way you did sinceÃâà you seem like it that way and your temps are very reasonable. > > Ãâà Ãâà Ãâà Ãâà Will let ya'll know. Going back to VaBch next month so I may get it done and check it before then. > > Thanks, Bob J. > > > > > > > > ____________ _________ _________ __ > > From: Leroy > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Fri, March 5, 2010 4:34:57 PM > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > Ãâà > > I am interested in this engine thermostat phenomenom. I messed with my cooling system for months and found a combination that works well for me. > > The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. > > I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. > > > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > > > I dropped my thermoststs̢̮â¬Å¡Ãâà to 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > > > > > ̢̮â¬Å¡Ãâà > > > > > > > > > > > > ____________ _________ _________ __ > > > From: ronmarabito2002 > > > To: WanderlodgeForum@ yahoogroups. com > > > Sent: Sun, February 28, 2010 1:58:50 PM > > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > > > ̢̮â¬Å¡Ãâà > > > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > > > > > Long day..... having fun. > > > > > > > > > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > San Antonio, TX > > > > > > > > > > |
03-07-2010, 05:29
A long afternoon
Mine will normally run220ish, but will quickly climb to230 and hold on any size of hill at all.
Rick Davis
1993 WBSA
Loudon, TN
From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Sat, March 6, 2010 1:08:35 PM Subject: [WanderlodgeForum] Re: A long afternoon Bob: My oil temperature runs there all the time. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In "WanderlodgeForum%40yahoogroups.com", Robert Johannesen > > Thanks, Leroy - sounds like we have gone through the same thought processes. I will check it soon. As an aviator myself, 230 degrees of oil temp bothers me! > Bob J > > > > > ____________ _________ _________ __ > From: Leroy > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sat, March 6, 2010 8:08:21 AM > Subject: [WanderlodgeForum] Re: A long afternoon > > Ãâ > The Alarmstat is located on the left hand side of the water pump in the water jacket of the engine on my coach. It is a bulb looking instrument with two wires attached to it. The original had screws attaching the wires attached to it. The replacement has slide on connections. If it has not been painted it may have the name Kysor on it. The temp range is stamped on the hex part of the instrument. BB part number for the 190 version which means nothing except for reference purposes is 1594951. You can see one at http://www.medallionis. com under switches, senders and sensors, pn 1002-07478-30. The NC version. > > As for oil temp mine runs in the 215- 230 range but is affected by OAT, radiator water temp and road speed. I have messed with that also. My understanding is there are two Detroit oil coolers which bolt onto the left side of the engine. They have a different number of cooling plates. It is cooled by the radiator water. So reduction of the average water temp reduces oil temp but only by about 5-8%. In winter my oil temp will run about 215 at 62mph. In summer is runs 230 at the same speed simply because the average running water temp increases. The only way to reduce oil temp would be to add an oil cooler. My conclusion on that issue has been I have not done it. If I did, I believe the way to do it would be to somehow have the pick up on the pressure side off the main oil filter cycling oil to a separate air cooled cooler and dump the cooled oil into the pan which would then reduce overall pan oil temp before it is reintroduced onto the main oil pump pick > up. Or have a larger engine oil cooler which is water cooled built. Probably cost prohibitive. > > I have had lengthy discussions with BB and Detroit. Detroit did not spec the Alarmstat in BB engines. BB engineers did and I was never able to determine why it was installed in the first place but speculate it was intended to have the fan idle to prevent dust from blowing all over creation, including being inducted into the fins of the radiator while operating off the highway at slower speeds. > > As a practical matter, the Alarmstat forces temps to run higher than I like. While it is important to heat up the oil to remove moisture this is accomplished at 180-200 or 230. In aircraft, oil temp typically runs 180-190 and all is well. > > So, in the summer I personally run my coach on fan override after I get on the highway and that keeps temps at a solid 190 on the water and around 220-230 on the oil. I simply shut off the fan override before leaving the highway and let the alarmstat control things them. In winter I allow the Alarmstat to do its thing. > > I know, the fan supposedly robs horsepower. I have not been able to prove that either using the computer. Besides, I have a solid argument regarding horsepower and that fan which I will not go into indepth here. It is simple. On the flat you are not using the HP. Climbing the mountain it is not available because the fan is on high: That assumes the HP rob was there in the first place. > > Hope this gives you some insight into the ops. > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ Leroy, I would like to know also! Thanks for your response. > > > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ Where is the alarmstat for the fan normally located? I will check and see what its setting is. My goal was to have all the̢̮â¬Å¡Ãâ engine temps run lower. My oil temp is now about 230 constantly. > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ I will go back an read my maintenance log to refresh my memory, because it has been about 10 years since I tried the change. I remember being very disappointed. I know I didn't change my alarmstat for the fan because I didn't realize I had one. It is probably in the hydraulic circuit between the pump and the valve that opens the flow and maybe I can read the setting on the device itself. > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ I will go back and research the system (I think I have the applicable BB prints)̢̮â¬Å¡Ãâagain because I do want it to run cooler (Oil temp and water temp) if possible. I am also not opposed to designing an in line oil cooler.̢̮â¬Å¡ÃâHaving it closer to the water temp is OK with me. My heat exchanger for the Oil and water is so close to the frame on the left side of the block that it cannot be removed to inspect or examine it. > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ I may set up and try my alarmstat the way you did since̢̮â¬Å¡Ãâyou seem like it that way and your temps are very reasonable. > > ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ̢̮â¬Å¡Ãâ Will let ya'll know. Going back to VaBch next month so I may get it done and check it before then. > > Thanks, Bob J. > > > > > > > > ____________ _________ _________ __ > > From: Leroy > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Fri, March 5, 2010 4:34:57 PM > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > ̢̮â¬Å¡Ãâ > > I am interested in this engine thermostat phenomenom. I messed with my cooling system for months and found a combination that works well for me. > > The engine thermostats do not control the fan cycles on my coach. I don't believe they do on yours. Could be wrong. An separate system incorporating an Alarmstat does that. Stock Alarmstats were 195 degrees with an approximate 8-10 degree spread. The fan cycled to high at 203-205 and back to about 193 at fan idle. I run a 190 degree Alarmstat with 180 degree thermostats. I can see the movement on the gauge and the VMSpc. My spread is between 188 and 195 depending on OAT. If I run my fan on override it holds at 180 in winter and 190 in summer. > > I sure would like to know how your fan is configured and why it would be cycling after you changed thermostats. If it ran 170 all the time it should never cycle but remain in idle or about 500rpm. > > > > --- In WanderlodgeForum@ yahoogroups. com, Robert Johannesen > > > > > > I dropped my thermoststsÃÆÃââââÂ¬Ã Â¡ÃÆÃ¢â¬Å¡Ãâto 170s for about 6 months and the fan kept cycling on and off so often I went back to stock after talking to Detroit. I probably still have them if you want to try them on your rig. > > > > > > ÃÆÃââââÂ¬Ã Â¡ÃÆÃ¢â¬Å¡Ãâ > > > > > > > > > > > > ____________ _________ _________ __ > > > From: ronmarabito2002 > > > To: WanderlodgeForum@ yahoogroups. com > > > Sent: Sun, February 28, 2010 1:58:50 PM > > > Subject: [WanderlodgeForum] Re: A long afternoon > > > > > > ÃÆÃââââÂ¬Ã Â¡ÃÆÃ¢â¬Å¡Ãâ > > > Mike: Why do you want to change thermostats to 170's? Good heat without overheat makes the engine run better and more efficiently. I think 180's is cool enough. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "mbulriss" <mbulriss@ .> wrote: > > > > > > > > I spent all afternoon (into the early evening) opening up the bed and then the innards to be able to replace alternator #1 - one more time. In mine, I also have to work around all the plumbing, which was conveniently installed in the way of the engine hatch! After opening the floor, you can't even see the alt!!! I have to stand on the tranny and kind of remove the alt by feel. I bought a new one and replaced it. Not going to screw around rebuilding the old one again - 7000 miles since the last time has soured me on rebuilds. Besides, the new one was the same price as the last rebuild. This is really not a fun job. > > > > > > > > After I finished installing the alt, I then installed a replacement turbo intake tube that I found in a 'reclamation center' (aka: truck junk yard) to replace the one that broke in South Padre. The weld job did not hold up. If you want a good laugh, I called Detroit to see about getting a new one, because I really wanted a new one. When I heard $500 for a piece of exhaust pipe, I decided to try to find a used one. If anyone knows of a place to get part number 5101394 (yup, it's stamped right on it) for way less than $500, let me know please. And I used to think Harley parts were high dollar! > > > > > > > > Man, I am beat up and sore all over! I left the floor open as I want to remove the 'infamous' coolant hoses to the air pump tomorrow. At least that's the current plan. I realllllly am not looking forward to that job! I think I will replace them with braided stainless steel hoses so I never have to do it again! > > > > > > > > While I was having fun, the wife pulled each screen window and washed them, did the Invisible Glass cleaning on each window, and then scrubbed each window track and silicon lubed them. They slide open really nice now. > > > > > > > > It seems my to-do list just keeps growing without getting shorter! Is it just me? I want to change the thermostats to 170s. I need to rebuild the Gast air pump. I have service the air dryer on the list. I plan to pull the electric heaters to clean them out. And on and on..... And I haven't even started on the wife's list of modifications yet! I keep wondering: Are we having fun yet? > > > > > > > > Long day..... having fun. > > > > > > > > > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > San Antonio, TX > > > > > > > > > > |
