Emergency shut down mod
04-26-2006, 00:52
Now would that be a dry powder or co2 extinguisher or water type
extinguisher. Since the marority of folks carry a dry type extinguisher due to the compact size. Diesel and gasoline engines would sustain a great deal of damage ingesting the dry powder type prevalent today. Since most dry powder extinguisers use Sodium bicarbonate as an extinguishing agent. I seriously question your logic.Also the amount of air moved in the combustion cycle would preclude the use of co2 and most certainly using a water type would create a lot of damage. A good dose of water would hydraulic the engine since as you know water is non-compressible Sodium Bicarbonate is used in our business as a paint removal agent it is very abrasive. I would think that an engine sucking in an abrasive agent such as 3 to 5 pounds of sodium bicarbonate would sustain just as much damage as a runaway. Certainly a major out of frame rebuild would be necessary in either case. In your research how many runaways versus number of diesel engines are involved? Inquiring minds would like to know But then again it is different strokes for different folks Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > There is only one sure fire way to shut down a runnaway diesel and > that is to shut off the air. Since it is caused by either oil or fuel > getting sucked into the intake past worn or blown turbocharger seals > then the only control you have is thru the air that it needs to keep > running. If this ever happens the quickest way to shut it down if > the emergency shut off does not work is to aim a fire extinguisher at > the air intake and give it a blast. > > Tom Warner > Vernon Center,NY > 1985 PT 40 > |
04-26-2006, 01:44
Yeah, I wondered about that. I have heard that CO2 would kill a runaway so I
carry the biggest one that will fit in the side compartment. Had an injector pump fail in the FC a while back, when it was inspected the tech said, "Lucky it didn't runaway", I nearly soiled myself at the thought. The real deal would probably be Halon, but you can't beat a intake plate to be sure. Mike Hohnstein ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 26, 2006 7:52 AM Subject: [WanderlodgeForum] Re: Emergency shut down mod Now would that be a dry powder or co2 extinguisher or water type extinguisher. Since the marority of folks carry a dry type extinguisher due to the compact size. Diesel and gasoline engines would sustain a great deal of damage ingesting the dry powder type prevalent today. Since most dry powder extinguisers use Sodium bicarbonate as an extinguishing agent. I seriously question your logic.Also the amount of air moved in the combustion cycle would preclude the use of co2 and most certainly using a water type would create a lot of damage. A good dose of water would hydraulic the engine since as you know water is non-compressible Sodium Bicarbonate is used in our business as a paint removal agent it is very abrasive. I would think that an engine sucking in an abrasive agent such as 3 to 5 pounds of sodium bicarbonate would sustain just as much damage as a runaway. Certainly a major out of frame rebuild would be necessary in either case. In your research how many runaways versus number of diesel engines are involved? Inquiring minds would like to know But then again it is different strokes for different folks Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > There is only one sure fire way to shut down a runnaway diesel and > that is to shut off the air. Since it is caused by either oil or fuel > getting sucked into the intake past worn or blown turbocharger seals > then the only control you have is thru the air that it needs to keep > running. If this ever happens the quickest way to shut it down if > the emergency shut off does not work is to aim a fire extinguisher at > the air intake and give it a blast. > > Tom Warner > Vernon Center,NY > 1985 PT 40 > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-26-2006, 02:30
I had it happen on a 3208 after a fuel injector broke, filling the
crankcase with enough diesel to hit the rods and churn it up. Happened in Chicago, ran full-throttle with the fuel shut off, ... fortunately it isn't difficult to overcome the 3208 with the brakes. Often it is simply the injection pump that causes the runaway (usually), cutting the fuel supply will kill it, spinning off a fuel filter so air gets in works in this case (or cutting a line, I guess the sledge-hammer is faster when you're saving an engine). I did watch a farmer try to stall a runaway tractor against a big oak tree, it dug big holes before he got it stopped. The flap on the PTs works pretty well usually, I haven't heard of it failing (except on one '86 which was on fire). Engine can't run without air no matter how much fuel you give it. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > been around several runaways,we shut them down by knocking the fuel > filter off with a hammer,shoving a raincoat in the air filter to try > to choke the engine down(it didnt work),the flap in the early DD's > don't work either,it will slow it down,but not shut it down.its hard > to stand there and try to save an engine when its running wide > open,take a sledge hammer,knock off a fuel line,then run! > randy > > > > have never seen a 4 cycle runaway But iam sure it can happen but > have > > had a 2000 horsepower GM runaway and blow it was neat 500 gallons > of > > old oil every where > > Stephen > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Scott: > > > > > > Two different engines and systems. My post concerns the PT's not > FC's. > > > Sorry for my not making that clear. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > http://home.swbell.net/rlf47/index.htm > > > > > > At 06:26 PM 4/25/2006 +0000, you wrote: > > > >"there is not a manual cable pull such as in the older Bird's" > > > > > > > >Does my '82 FC have one of these? Where is it? > > > > > > > >Scott Forman > > > >82 FC35RB > > > >Memphis > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > > > > Good morning everyone: > > > > > > > > > > There, recently, has been a situation that needs to be > addressed > > > >with a > > > > > modification added to the '88 through 90's Birds. > > > > > > > > > > I am working on drawing a schematic which adds a Bosh relay > and a > > > >switch > > > > > located in an accessory slot on the dash, for the engine > emergency > > > >shut > > > > > down of the engine. > > > > > > > > > > Problem: A relay, # 34 welded the contacts and the Coach > could not > > > >be shut > > > > > down with either the dash or rear key switch and there is > not a > > > >manual > > > > > cable pull such as in the older Bird's. > > > > > > > > > > Solution: Adding a relay to the fuel shut off valve > circuit, that > > > >is > > > > > controlled by a switch on the dash. The relay coil will be > on the > > > >switch > > > > > and the wire going to the fuel shut off valve on the engine > will be > > > >on the > > > > > normally closed side of the relay, thus if the added relay > ever > > > >fails then > > > > > it will fail closed keeping the power on the fuel shut off > valve. > > > >By > > > > > switching the relay, the circuit to the fuel shut off valve > is > > > >opened up > > > > > and you have engine shut down. > > > > > > > > > > I will try to get this modification added to the files > section this > > > > > weekend, with the correct wire numbers/colors and > connections for > > > >those who > > > > > might be interested. > > > > > > > > > > This circuit will be added to Ken and Patti > Marsh's "ToWanda" Which > > > >is an > > > > > '89PTWB. > > > > > > > > > > So far as I know, this is a first with this "no shut down" > > > >problem. It, > > > > > seemingly has always been, "I can't get it to start" problem. > > > > > > > > > > > > > > > > > > > > > > > > |
04-26-2006, 03:15
I always carry a Halon and a foam by the engine, not sure the Halon
would be big enough for a wide-open 10.2liter engine or bigger still the over 700cu-in Detroit. A lot of air will go through that engine at high-rpms before it spools down to zero, better have enough Co2 for the whole event. Go big is a good idea. I'd side with a plate, might not shut it off completely but easier to kill an idling engine with an extinguisher or whatever, and I won't stand next to a runaway no matter what it's worth, forged rods come out fast. That's why Randy says "then run away". - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Yeah, I wondered about that. I have heard that CO2 would kill a runaway so I carry the biggest one that will fit in the side compartment. Had an injector pump fail in the FC a while back, when it was inspected the tech said, "Lucky it didn't runaway", I nearly soiled myself at the thought. > The real deal would probably be Halon, but you can't beat a intake plate to be sure. > Mike Hohnstein |
04-26-2006, 14:03
wrote: >ahhh tom,that is a classic classroom approach to shutting it down,when in real life in a not perfect world and an engine running wide open not 3 feet from you about the only thing you can do is knock off a filter or line and hope it runs out of fuel before it blows all to hell. i've tried the air thing,and the only way that works is if you have the air cleaner off the engine and you have a board handy that will cover the air horn,not almost cover it,and it has to be small enough to get it in that area,then of course you have to have the nerve to hold that board over the air horn until it dies.most times to use that board on a truck means you have to climb up on a tire to get to the air horn. remember,you have only seconds to either run,or be a hero. i shoved a raincoat into a detroit blower to try to cut the air off,it slowed down about 300 rpm's,i took a sledge hammer and knocked the fuel filter off,but before it died it slung the clutch out,all over the parking lot.that was the first one i had run away,after that i never tried the air thing again.. randy > There is only one sure fire way to shut down a runnaway diesel and > that is to shut off the air. Since it is caused by either oil or fuel > getting sucked into the intake past worn or blown turbocharger seals > then the only control you have is thru the air that it needs to keep > running. If this ever happens the quickest way to shut it down if > the emergency shut off does not work is to aim a fire extinguisher at > the air intake and give it a blast. > > Tom Warner > Vernon Center,NY > 1985 PT 40 > |
04-26-2006, 14:08
>stephen,the only thing that might work is halon,and a lot of it,of course you know thats not available anymore.co2? never happen,with an engine running wide open,you could never get the volume from a co2 5lb cylinder to do anything.. randy > Now would that be a dry powder or co2 extinguisher or water type > extinguisher. Since the marority of folks carry a dry type > extinguisher due to the compact size. Diesel and gasoline engines > would sustain a great deal of damage ingesting the dry powder type > prevalent today. Since most dry powder extinguisers use Sodium > bicarbonate as an extinguishing agent. I seriously question your > logic.Also the amount of air moved in the combustion cycle would > preclude the use of co2 and most certainly using a water type would > create a lot of damage. > A good dose of water would hydraulic the engine since as you know > water is non-compressible > Sodium Bicarbonate is used in our business as a paint removal agent > it is very abrasive. I would think that an engine sucking in an > abrasive agent such as 3 to 5 pounds of sodium bicarbonate would > sustain just as much damage as a runaway. Certainly a major out of > frame rebuild would be necessary in either case. > In your research how many runaways versus number of diesel engines are > involved? Inquiring minds would like to know > > But then again it is different strokes for different folks > > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > > > There is only one sure fire way to shut down a runnaway diesel and > > that is to shut off the air. Since it is caused by either oil or fuel > > getting sucked into the intake past worn or blown turbocharger seals > > then the only control you have is thru the air that it needs to keep > > running. If this ever happens the quickest way to shut it down if > > the emergency shut off does not work is to aim a fire extinguisher at > > the air intake and give it a blast. > > > > Tom Warner > > Vernon Center,NY > > 1985 PT 40 > > > |
04-26-2006, 14:14
>i never had one runaway while driving it. and the turboed detroits don't have a flap.and the old non turbos with a flap are allold,and the flap is a leater type thing,that shrinks with time.the flap will slow down the engine to a safe speed randy > I had it happen on a 3208 after a fuel injector broke, filling the > crankcase with enough diesel to hit the rods and churn it up. > Happened in Chicago, ran full-throttle with the fuel shut off, ... > fortunately it isn't difficult to overcome the 3208 with the brakes. > > Often it is simply the injection pump that causes the runaway > (usually), cutting the fuel supply will kill it, spinning off a fuel > filter so air gets in works in this case (or cutting a line, I guess > the sledge-hammer is faster when you're saving an engine). > > I did watch a farmer try to stall a runaway tractor against a big oak > tree, it dug big holes before he got it stopped. > > The flap on the PTs works pretty well usually, I haven't heard of it > failing (except on one '86 which was on fire). Engine can't run > without air no matter how much fuel you give it. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > been around several runaways,we shut them down by knocking the fuel > > filter off with a hammer,shoving a raincoat in the air filter to > try > > to choke the engine down(it didnt work),the flap in the early DD's > > don't work either,it will slow it down,but not shut it down.its > hard > > to stand there and try to save an engine when its running wide > > open,take a sledge hammer,knock off a fuel line,then run! > > randy > > > > > > have never seen a 4 cycle runaway But iam sure it can happen but > > have > > > had a 2000 horsepower GM runaway and blow it was neat 500 > gallons > > of > > > old oil every where > > > Stephen > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Scott: > > > > > > > > Two different engines and systems. My post concerns the PT's > not > > FC's. > > > > Sorry for my not making that clear. > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > http://home.swbell.net/rlf47/index.htm > > > > > > > > At 06:26 PM 4/25/2006 +0000, you wrote: > > > > >"there is not a manual cable pull such as in the older Bird's" > > > > > > > > > >Does my '82 FC have one of these? Where is it? > > > > > > > > > >Scott Forman > > > > >82 FC35RB > > > > >Memphis > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > > > > > > > Good morning everyone: > > > > > > > > > > > > There, recently, has been a situation that needs to be > > addressed > > > > >with a > > > > > > modification added to the '88 through 90's Birds. > > > > > > > > > > > > I am working on drawing a schematic which adds a Bosh relay > > and a > > > > >switch > > > > > > located in an accessory slot on the dash, for the engine > > emergency > > > > >shut > > > > > > down of the engine. > > > > > > > > > > > > Problem: A relay, # 34 welded the contacts and the Coach > > could not > > > > >be shut > > > > > > down with either the dash or rear key switch and there is > > not a > > > > >manual > > > > > > cable pull such as in the older Bird's. > > > > > > > > > > > > Solution: Adding a relay to the fuel shut off valve > > circuit, that > > > > >is > > > > > > controlled by a switch on the dash. The relay coil will be > > on the > > > > >switch > > > > > > and the wire going to the fuel shut off valve on the engine > > will be > > > > >on the > > > > > > normally closed side of the relay, thus if the added relay > > ever > > > > >fails then > > > > > > it will fail closed keeping the power on the fuel shut off > > valve. > > > > >By > > > > > > switching the relay, the circuit to the fuel shut off valve > > is > > > > >opened up > > > > > > and you have engine shut down. > > > > > > > > > > > > I will try to get this modification added to the files > > section this > > > > > > weekend, with the correct wire numbers/colors and > > connections for > > > > >those who > > > > > > might be interested. > > > > > > > > > > > > This circuit will be added to Ken and Patti > > Marsh's "ToWanda" Which > > > > >is an > > > > > > '89PTWB. > > > > > > > > > > > > So far as I know, this is a first with this "no shut down" > > > > >problem. It, > > > > > > seemingly has always been, "I can't get it to start" > problem. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
04-26-2006, 14:19
runaway from a runaway!hahaa! and you don't need any coffee for a little while! randy > > I always carry a Halon and a foam by the engine, not sure the Halon > would be big enough for a wide-open 10.2liter engine or bigger still > the over 700cu-in Detroit. A lot of air will go through that engine at > high-rpms before it spools down to zero, better have enough Co2 for the > whole event. Go big is a good idea. > > I'd side with a plate, might not shut it off completely but easier to > kill an idling engine with an extinguisher or whatever, and I won't > stand next to a runaway no matter what it's worth, forged rods come out > fast. That's why Randy says "then run away". > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@> wrote: > > > > Yeah, I wondered about that. I have heard that CO2 would kill a > runaway so I carry the biggest one that will fit in the side > compartment. Had an injector pump fail in the FC a while back, when it > was inspected the tech said, "Lucky it didn't runaway", I nearly soiled > myself at the thought. > > The real deal would probably be Halon, but you can't beat a intake > plate to be sure. > > Mike Hohnstein > |
