Squirell Cage Fan
07-30-2006, 04:06
Squirell Cage Fan
San Durrett,
I could not find any markings on the motor so I measured it. It is 3 1/2" long and 8" around the body of the motor. You can contact me off line or by phone if this is close to what you have. Howard Truitt Camilla, Ga. 86 8V92 PT40 229-336-7863 truitt44 [at] bellsouth [dot] net ----- Original Message ----- From: Samddurrett@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 5:52 PM Subject: Re: [WanderlodgeForum] Re: Squirell Cage Fan I have 2 or 3 12 volt fan motors that came out of the squirell cage fans on the dash AC unit of my bird. I dont know if they are close to what you need or not. Sam Durrett 68 31 FC TN In a message dated 7/29/2006 4:37:19 P.M. Central Standard Time, truitt44@... writes: --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] |
07-31-2006, 16:04
Squirell Cage Fan
Bill: I have found that running the fan override while entering a park after a
trip significantly reduces the squirrel cage fan operating time. Makes sense, the radiator cooling fan on override runs at about 1800RPM blowing air over the engine and out the vents. Further, I stay on top of the temps while traveling and am not afraid to use the fan override. It has worked for me. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 7:01 PM Subject: Re: [WanderlodgeForum] Re: Squirell Cage Fan Bill, This is 12vdc and sits at rear above the engine compartment and is used to cool down engine after shutdown Howard ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 6:30 PM Subject: [WanderlodgeForum] Re: Squirell Cage Fan Howard, If Grainger has your part, they have a good web site. http://www.grainger.com Type in centrifugal fan motors , search and you will find a replacement. Or try to get the part number off of your motor and it may cross to a Grainger part number. These motors are not too costly you may want to replace the whole fan & motor. I am not sure, if you are looking for 12V DC or 110v AC. I used a 110V quiet AC computer fan to circulate air through the bay that houses the Battery Charger. Bill 88 FC Michigan Way toooooooo hot today! --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Stephen, > I will have to check on the numbers. BB parts does not have it. They reccomended checking with Grainger. > I just thought I would ask if anyone had one. > Howard Truitt > Camilla, Ga. > 86 PT40 > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 29, 2006 4:33 PM > Subject: [WanderlodgeForum] Re: Squirell Cage Fan > > > Howard > would there be any numbers or makers marks on that little beauty > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Fellows, > > I need a squirell cage fan motor for the fan in the engine > compartment Does anyone have one they they can part with. > > Howard Truitt > > Camilla, Ga. > > 86 8V92 PT40 > > > > [Non-text portions of this message have been removed] > > > > > > > > > ---------------------------------------------------------- ----------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 > > > [Non-text portions of this message have been removed] > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
