RV 3012 M
05-30-2008, 05:04
RV 3012 M
Kurt,
I may be interested in your grill & slide. I need to check for
enough room to put it in one of my curb side bays though. Dimensions
are approx.?
Terry
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
bumpersbird wrote:
Terry,
Here is the responce from Xantrex Customer Serive.
I did buy 2 of these units. They are new in the box and Sun Electric
is an aurthorized dealer so the warrantie should be good.
I spoke with several tech guys and of course got several diffrent
answers. About all aspects of these units.
I was most impressed with a guy from Buddy Gregg Motorhomes in
Knoxville TN. Wayne Clapp a veteran BB Tech. His first question was
did I plan on keeping the coach? Well of course. Then you must get
these inverters out of the engine compartment and into one of the
bays. So were are going the reinvent the wheel. Not really a problem
the old compartment is really not large enough for the new inveters.
With the inverter box empty I think I'll throw in a couple more
Lifeline gell cells. That will make 8 house batts. Wayne also told me
he can with the addition of a few relays make the AC run on Batts.
With the additional 2 Lifeline's and the 2 new invetrers running off
of 8 Batts. in 2, four Batt. banks I should be able to run 2 AC'S.
The 300 amp alternator should be able to tow the line. I would be
nice to run the roof air with out the generator. Any help in fuel
economy is welcomed.
Any body want to buy a electric grill for their coach? Mine is coming
out, slide and electric components included.
I also bought 2 RC7/GS controlers off of e-bay. The were the best
deal for the $'s.
Kurt Horvath
95 PT-42 WLWB
[ref:00D3Wjr.500350dxJ:ref]
Dear kurt daniel horvath,
"Can the RC/GS Remote Panel be use in place of the RC7."
No , this will not work properly. You are better off trying to locate
an RC7 by seaching the internet and the many dealers who may have a
NOS unit.
"Is the 24 month warrantie good on these new in the box units?"
If the unit is new in the box and purchased from proper dealer who
purchased it from a Xantrex Distributor than we shall honor the
warranty.
Xantrex Technical Support
Customer Service Operations
Xantrex Technology Inc.
Email: "customerservice%40xantrex.com"
Website: www.xantrex.com
t: (360) 925-5097 / (800) 670-0707
f: (360) 435-2636
Confidentiality Notice: This e-mail message, including any
attachments, is for the sole use of any recipient(s) and may contain
confidential and privileged information. Any unauthorized review,
use, disclosure or distribution is prohibited. If you are not the
intended recipient, please contact the sender by reply e-mail and
destroy all copies of the original message.
--------------- Original Message ---------------
To: "customerservice%40xantrex.com"
Subject: Fw: Case Number (00102708) [ ref:00D3Wjr.500350dxJ:ref
----Original Message----
Date: 05/21/2008 3:27 PM
To: <"customerservice%40xantrex.com">
Subj: RE: Case Number (00102708) [ ref:00D3Wjr.500350dxJ:ref ]
Dear Mr.Nick Klien.
If so, are there any peculiarities involed or is it just a simple
choice of which control is available.
Yes price is a consideration here the old unites are new and are an
exceptional deal at this time.
Thank You for your time,
Kurt Horvath
Terry Neal "bird@..." wrote:
> Hi Kurt,
> Did you receive a response from Xantrex about the RC/GS remote to
> control this RV 3012 M? I am thinking about ordering one too &
replace
> all of the old components such as the Redline unit in my PT. Can't
find
> any info about the two working together.
> Terry
> bumpersbird wrote:
> > Here is my responce from Xantrex to the RV3012M question.
> > I am awaiting a second e-mail to confirm if the new control
panel
> > the RC/GS will funtion as well as the older RC7.
> > According to my local tech guy it will. You should be able to
set
> > the inverter/charger to your particular application.
> > Kurt Horvath
> > 95 PT-42
> > Dear Kurt Horvath,
> > They are very similar units. Below is an explanation of the
RV3012M
> > model and then the RV 3012 GS :
> > The RV3012M, which is 3000 watts respectively. These units
were
only
> > used for Monaco coaches, and the M designation referred to a
series
> > of default programming items requested by Monaco. (See the
section
> > on “RC7 & RC7GS Setup Menus”.)
> > Two knockouts on the inverter were left open at the factory.
> > Otherwise they were physically indistinguishable from the
regular
> > version, and had no other unique features. Warranty is the
same.
> > The "software" defaults which may be different from standard
models
> > were:
> > SEARCH SENSE – DEFEAT
> > BAT CAPACITY – AUTO
> > BAT TYPE – LIQUID LEAD ACID
> > CHARGE RATE – 80%
> > The RV 3012 GS is the newer version that replaced the RV
series.
> > This series looks almost the same as the original RV and
largely
has
> > the same specs and functions. Its main visual distinction is
that
> > it only has two com ports, not three. There were a few
enhancements
> > made with the Auto Gen Start feature and programming.
> > Both models were designed for RV use.
> > "RV3012 M be reprogramed to standard specs? If so what would
> > cost be?"
> > You could program it yourself if you have a RC7, but if you
do not
> > have an RC7 then you might be able to locate one by doing
a "google"
> > search of the dealers online otherwise they are no longer
available
> > as they have been obsolete for awhile now.
> > It would be good to update the system rather than repair the
freedom
> > if they are really 15 years old.
> > I suggest the newer RV 3012 GS model rather than the "M"
model.
> > But if it is a big difference in cost the "M" model will be
fine
if
> > an RC7 comes with it.
> > For all correspondence regarding this issue, please make sure
to
> > include the case number (00102708) in the subject line of the
email.
> > Technical Support
contain
review,
> > Case number: 00102708
> > Case Subject: Xantrex RV 3012 M Inverter / Charger
> > Description: Could you please explain the diffrence between
> > model RV 3012 M and the new RV 3012 GS. Is it just an older
model
or
> > are there significant diffrences between the two units?
RV3012 M
be
> > reprogramed to standard specs? If so what would the cost
be?Can
> > model
> > I have the old Freedom Combi aqua blue colored units in my
coach.
> > They are 15 years old. would it be better to replace these
unites
> > with the RV 3012 M or should I just have them refurbished. I
am in
> > the process of refubishing all the systems so now is a good
time
to
> > do the inverter sysytem.
> > Thanks for your time,
> > Kurt Horvath
> > <"Wanderlodge"Forum%40yahoogroups.com>,
"Dorn Hetzel"
> > wrote:
> > > ---------- Forwarded message ----------
> > > From: Nick Klein >
> > > Date: Tue, May 20, 2008 at 3:42 PM
> > > Subject: RE: Case Number (00102618) [
ref:00D3Wjr.500350ZIy:ref ]
> > > To: "dorn@"
> > > [ref:00D3Wjr.500350ZIy:ref]
> > > Dear dorn,
> > > They are basically exactly the same units, but below is
an
> > explanation:
> > > This line consisted of models RV2012M, RV2512M, and
RV3012M,
which
> > were
> > > 2000, 2500 and 3000 watts respectively. These units were
only
> > used for
series of
> > default
> > > programming items requested by Monaco. (See the section
on "RC7
> > RC7GS
> > > Setup Menus".)
factory.
> > Otherwise they
> > > were physically indistinguishable from the regular
version, and
> > had no other
> > > unique features. Warranty is the same.
standard
> > models were:
> > > SEARCH SENSE - DEFEAT
> > > BAT CAPACITY - AUTO
> > > BAT TYPE - LIQUID LEAD ACID
> > > CHARGE RATE - 80%
> > > Yes, both models were designed for RV use.
sure to
> > include the
> > > case number (00102618) in the subject line of the email.
> > > Technical Support
any
> > attachments, is
confidential
> > and
> > > privileged information. Any unauthorized review, use,
disclosure or
> > > distribution is prohibited. If you are not the intended
recipient,
> > please
> > > contact the sender by reply e-mail and destroy all
copies of the
> > original
> > > message.
> > > Case number: 00102618
> > > Case Subject: how is rv3012M different from other rv3012
> > > Description: Can you explain the differences between
RV3012M and
> > other
> > > RV3012 models. What does M series software mean? Are
these
> > models still
> > > suitable for an RV application?
05-30-2008, 05:53
RV 3012 M
Yeh they told me the same thing, they guy in Bombay told me it stood
for Mobile.
After a lot of question and some industrial espionage they m stands
for Monaco. They ordered these units for thier coaches with some
specific software defaults. All of these can be reprogramed with the
control units.
According to Xantrex there are only minor and superfical modifactions
to any of the RV series inverters/chargers, from what I understand
it's mostly the control panels.
Kurt Horvath
95 PT-42 WLWB
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> A guy at Sun Electronics said the "M" is for "Marine"
units...interesting.
> On Fri, May 30, 2008 at 9:32 AM, bumpersbird
> > Terry,
Electric
was
problem
inveters.
told me
off
coming
> > deal for the $'s.
> > Kurt Horvath
> > 95 PT-42 WLWB
locate
a
> > NOS unit.
> > warranty.
> > Email: customerservice@...
> > Website: http://www.xantrex.com
> > f: (360) 435-2636
contain
> > From: kurt daniel horvath [kguns@... ]
> > To: customerservice@...
> > Subject: Fw: Case Number (00102708) [ ref:00D3Wjr.500350dxJ:ref ]
> > From: kguns@...
> > To: >
> > Dear Mr.Nick Klien.
an
> > Kurt Horvath
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > Terry Neal wrote:
> > > Hi Kurt,
to
> > replace
Can't
> > find
> > > Terry
panel
set
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > Dear Kurt Horvath,
> > RV3012M
were
> > only
> > series
section
regular
same.
> > models
> > > > were:
> > > > BAT CAPACITY – AUTO
> > > > CHARGE RATE – 80%
series.
largely
> > has
that
> > enhancements
> > > > cost be?"
do not
> > a "google"
> > available
> > freedom
model.
fine
> > if
to
> > email.
> > > > Technical Support
> > contain
review,
model
> > or
RV3012 M
> > be
> > > > reprogramed to standard specs? If so what would the cost be?
Can
> > the
> > > > model
coach.
unites
am in
time
> > to
> > > > Kurt Horvath
> > > > 2540yahoogroups.com>>,
> > "Dorn Hetzel"
> > > > > From: Nick Klein
> > > > > To: "dorn@"
> > > > > Dear dorn,
> > > > > They are basically exactly the same units, but below is an
> > > > explanation:
> > > > > This line consisted of models RV2012M, RV2512M, and RV3012M,
> > which
> > > > were
only
> > > > used for
> > > > > Monaco coaches, and the M designation referred to a series
of
> > > > default
on "RC7
> > > > RC7GS
> > > > > Setup Menus".)
> > > > Otherwise they
> > > > > were physically indistinguishable from the regular version,
> > > > had no other
> > > > models were:
> > > > > BAT CAPACITY - AUTO
> > > > > CHARGE RATE - 80%
sure to
> > > > include the
> > > > > Technical Support
> > > > attachments, is
> > confidential
> > > > and
> > disclosure or
> > recipient,
> > > > please
> > > > > contact the sender by reply e-mail and destroy all copies
of the
> > > > original
> > > > > message.
RV3012M and
> > > > other
> > > > > RV3012 models. What does M series software mean? Are these
> > > > models still
> Curt Sprenger
> 1987 PT38 8V92 "MacAttack Racing"
> Anaheim Hills, CA
05-30-2008, 05:59
RV 3012 M
Terry,
Just to be sure I called Sun Electronics again to verify their status
as a Xanterx dealer and they confirmed that they are a Xantrex dealer.
I would like to get this all done in the next 2 to 3 weeks but if
Icould look into the future, you know what I mean.
I am still working on the engine bay cooling fans and I just got
a '07 DDEC IV ECM with it programing to my coach as a back-up. So
I've got a lot stuff to play with.
Kurt Horvath 95 PT-42 WLWB
--- In WanderlodgeForum@yahoogroups.com, Terry Neal wrote:
> Thanks Kurt. Nice report.
> I too was getting differing stories from different people. One of
> techs at Xantrex told me Sun Electronics wasn't even an authorized
> dealer or distributor & there was no record of them in their
listing.
> Of course, he didn't speak English that I could understand real
well so
> he may have be sitting in Bombay? Also, he kept saying there was
no RV
> 3012 "M" inverter either.
> In my PT, to install an inverter outside the engine compartment
means I
> change a lot of wiring. Yours is probably the same. May be the
best
> solution though. I was also thinking I may be able to build a
> compartment where the Rediline used to be and put it in there?
Like
> your idea of running a couple of ACs with the Detroit while
underway. I
> take it you are going to wire your system with the Gen Start
feature.
> That would be a good idea too.
> Do you have a time frame for all of this? I may wait a little
while to
> see how you accomplish all of the changes. Please share your
progress
> with us. I much appreciate it.
> Terry
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> bumpersbird wrote:
> > Terry,
Electric
was
problem
inveters.
told me
off
coming
> > deal for the $'s.
> > Kurt Horvath
> > 95 PT-42 WLWB
locate
a
> > NOS unit.
> > warranty.
> > f: (360) 435-2636
contain
> > From: kguns@...
> > To: >
> > Dear Mr.Nick Klien.
an
> > Kurt Horvath
> > , Terry Neal
> > > Hi Kurt,
to
> > replace
Can't
> > find
> > > Terry
panel
set
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > Dear Kurt Horvath,
> > RV3012M
were
> > only
> > series
section
regular
same.
> > models
> > > > were:
> > > > BAT CAPACITY – AUTO
> > > > CHARGE RATE – 80%
series.
largely
> > has
that
> > enhancements
> > > > cost be?"
do not
> > a "google"
> > available
> > freedom
model.
fine
> > if
to
> > email.
> > > > Technical Support
> > contain
review,
model
> > or
RV3012 M
> > be
Can
> > the
> > > > model
coach.
unites
am in
time
> > to
> > > > Kurt Horvath
> > > > , "Dorn Hetzel"
> > > > > From: Nick Klein
> > > > > To: "dorn@"
> > > > > Dear dorn,
> > > > explanation:
> > which
> > > > were
only
> > > > used for
of
> > > > default
on "RC7
> > > > RC7GS
> > > > > Setup Menus".)
> > > > Otherwise they
> > > > had no other
> > > > models were:
> > > > > BAT CAPACITY - AUTO
> > > > > CHARGE RATE - 80%
sure to
> > > > include the
> > > > > Technical Support
> > > > attachments, is
> > confidential
> > > > and
> > disclosure or
> > recipient,
> > > > please
of the
> > > > original
> > > > > message.
RV3012M and
> > > > other
> > > > models still
05-30-2008, 07:28
RV 3012 M
In my 77FC35 the batteries are at the far left front corner, no space for the inverter in their compartment anyway.
The current battery charger (not an inverter) is about midway back on the left side, same compartment as sewage host storage, probably ten feet from the batteries, doesn't really seem like an optimum location for the Xantrex.
Would I be crazy to put it inside the coach? There's a storage compartment right behind the drivers seat that's probably big enough, and within 2 feet of the batteries.
Another question. The Xantrex hookup diagrams seem to show the batteries directly connected to the 3012, and all coach loads hung behind it. Since I have combined coach and starting batteries in my 77, I don't think I should be running starting current through the 3012?
I was considering pulling the generator, which we never ever use, and filling that compartment with "house" batteries and a more weatherproof box for the inverter... Too whacky?
Dorn Hetzel
77FC35
Hogansville, GA
On Fri, May 30, 2008 at 1:59 PM, bumpersbird <"bumpersbird@yahoo.com"> wrote:
Terry,
listing.
well so
no RV
means I
best
Like
underway. I
feature.
while to
progress
> Terry
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> bumpersbird wrote:
> > Terry,
Electric
was
problem
inveters.
told me
off
coming
> > deal for the $'s.
> > Kurt Horvath
> > 95 PT-42 WLWB
locate
a
> > NOS unit.
> > warranty.
> > f: (360) 435-2636
contain
> > From: kguns@...
> > To: >
> > Dear Mr.Nick Klien.
an
> > Kurt Horvath
> > , Terry Neal
> > > Hi Kurt,
to
> > replace
Can't
> > find
> > > Terry
panel
set
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > Dear Kurt Horvath,
> > RV3012M
were
> > only
> > series
section
regular
same.
> > models
> > > > were:
> > > > BAT CAPACITY – AUTO
> > > > CHARGE RATE – 80%
series.
largely
> > has
that
> > enhancements
> > > > cost be?"
do not
> > a "google"
> > available
> > freedom
model.
fine
> > if
to
> > email.
> > > > Technical Support
> > contain
review,
model
> > or
RV3012 M
> > be
Can
> > the
> > > > model
coach.
unites
am in
time
> > to
> > > > Kurt Horvath
> > > > , "Dorn Hetzel"
> > > > > From: Nick Klein
> > > > > To: "dorn@"
> > > > > Dear dorn,
> > > > explanation:
> > which
> > > > were
only
> > > > used for
of
> > > > default
on "RC7
> > > > RC7GS
> > > > > Setup Menus".)
> > > > Otherwise they
> > > > had no other
> > > > models were:
> > > > > BAT CAPACITY - AUTO
> > > > > CHARGE RATE - 80%
sure to
> > > > include the
> > > > > Technical Support
> > > > attachments, is
> > confidential
> > > > and
> > disclosure or
> > recipient,
> > > > please
of the
> > > > original
> > > > > message.
RV3012M and
> > > > other
> > > > models still
05-30-2008, 07:42
RV 3012 M
Hi Dorn,
I picked up one of the 3012's and got the RC7 too. Like you was
curious about the wiring so gave Xantrex a call, they said you can
leave the wiring the way it is, but you loose the ability to measure
the current flow from the batteries. Not a big deal as we have the
shunts on the + side of the batteries.
HTH, Joe
'87 PT40
San Francisco
--- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel"
space for
on the
feet from
> Xantrex.
compartment
2 feet
> of the batteries.
batteries
Since I
should
weatherproof box
> Dorn Hetzel
> 77FC35
> Hogansville, GA
05-30-2008, 07:56
RV 3012 M
Terry, have you had any service tech look at your Cruise Airs? My front one works, ok. The mid one needs help. The rear, I gave the compressor to Ralph a few years back when I installed a roof air.
83PT40
Livingston, Montana
wishing that I at least could open the windows instead of running the HEAT!!
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
05-30-2008, 08:18
RV 3012 M
I was considering a split at the batteries to the starter and the 3012 and put everything else behind the 3012, if I can isolate the starter from everything else.
On Fri, May 30, 2008 at 3:42 PM, joepat50 <"jgarner@dslextreme.com"> wrote:
Hi Dorn,
HTH, Joe
'87 PT40
San Francisco
--- In "WanderlodgeForum%40yahoogroups.com", "Dorn Hetzel"
space for
on the
feet from
> Xantrex.
compartment
2 feet
> of the batteries.
batteries
Since I
should
weatherproof box
> Dorn Hetzel
> 77FC35
> Hogansville, GA
05-30-2008, 11:35
RV 3012 M
Thanks much Kurt. Sounds like you do have a few big projects
underway. I am going to buy one of the RV 3012 Ms & the RC7/GS
remote. Looks like a very good setup & you can't beat the cost for
the RV3012M.
I wonder if I could run one of my ACs on a single 3000 watt? I have
the 3 basement ACs. I only have 2 of the 4D batteries in the back now
to run the house & engine starting. I would need to beef up the
batteries but I can do that by stacking them into the space the
Rediline used to sit in plus build a new shelf above that space. Have
another gen set battery up front.
Terry
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
bumpersbird wrote:
Terry,
listing.
well so
no RV
means I
best
Like
underway. I
feature.
while to
progress
> Terry
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> bumpersbird wrote:
> > Terry,
Electric
diffrent
question
was
must get
problem
inveters.
more
told me
Batts.
running
off
AC'S.
would be
fuel
is
coming
best
> > deal for the $'s.
> > Kurt Horvath
> > 95 PT-42 WLWB
to
locate
have
a
> > NOS unit.
units?"
dealer who
> > warranty.
> > Email: customerservice@... <"customerser"vice%40xantrex.com>
> > f: (360) 435-2636
contain
review,
> > From: kurt daniel horvath [kguns@... <"kguns%"40hughes.net>]
> > To: customerservice@... <"customerser"vice%40xantrex.com>
> > From: kguns@... <"kguns%"40hughes.net>
> > To: ... <"customerser"vice%40xantrex.com>>
> > Dear Mr.Nick Klien.
simple
are
an
> > Kurt Horvath
Terry Neal
> > > Hi Kurt,
remote
to
too &
> > replace
PT.
Can't
> > find
> > > Terry
question.
control
panel
be able to
set
> > > > Kurt Horvath
> > > > 95 PT-42
> > > > Dear Kurt Horvath,
explanation of the
> > RV3012M
These units
were
> > only
referred to a
> > series
(See the
section
factory.
from the
regular
is the
same.
standard
> > models
> > > > were:
> > > > BAT CAPACITY – AUTO
> > > > CHARGE RATE – 80%
the RV
series.
RV and
largely
> > has
distinction is
that
few
> > enhancements
programming.
what would
> > > > cost be?"
but if you
do not
doing
> > a "google"
longer
> > available
repair the
> > freedom
the "M"
model.
will be
fine
> > if
make sure
to
line of the
> > email.
> > > > Technical Support
including any
> > contain
unauthorized
review,
you are not
reply e-mail
between
an older
model
> > or
units?
RV3012 M
> > be
cost be?
Can
> > the
> > > > model
units in my
coach.
replace these
unites
refurbished. I
am in
is a good
time
> > to
> > > > Kurt Horvath
"Dorn Hetzel"
> > > > > From: Nick Klein >
> > > > > To: "dorn@"
> > > > > Dear dorn,
below is an
> > > > explanation:
> > which
> > > > were
units were
only
> > > > used for
to a series
of
> > > > default
the section
on "RC7
> > > > RC7GS
> > > > > Setup Menus".)
at the factory.
> > > > Otherwise they
regular version,
> > > > had no other
from standard
> > > > models were:
> > > > > BAT CAPACITY - AUTO
> > > > > CHARGE RATE - 80%
please make
sure to
> > > > include the
the email.
> > > > > Technical Support
including any
> > > > attachments, is
contain
> > confidential
> > > > and
review, use,
> > disclosure or
intended
> > recipient,
> > > > please
all copies
of the
> > > > original
> > > > > message.
other rv3012
between
RV3012M and
> > > > other
mean? Are these
> > > > models still
05-30-2008, 12:11
RV 3012 M
Dorn
put the inverter in the first bay behind the batteries it is 8 feet
and just run bigger wire to supply the inverter
Stephen 77fc35 same as yours
905 328 0162
dupreeproducts.com
space for
on the
feet from
> Xantrex.
compartment
2 feet
> of the batteries.
batteries
Since I
should
weatherproof box
> Dorn Hetzel
> 77FC35
> Hogansville, GA
> On Fri, May 30, 2008 at 1:59 PM, bumpersbird wrote:
> > Terry,
> > --- In
> > the
> > listing.
> > well so
> > no RV
> > means I
> > best
> > Like
> > underway. I
> > feature.
> > while to
> > progress
> > > Terry
> > > Terry Neal
> > > Bozeman, MT
> > > 82PT40 6V92TA
> > > 74FC34 6V53T
> > > bumpersbird wrote:
> > > > Terry,
> > Electric
> > was
> > problem
> > inveters.
> > told me
> > off
> > coming
> > > > deal for the $'s.
> > > > Kurt Horvath
> > > > 95 PT-42 WLWB
> > locate
> > a
> > > > NOS unit.
> > > > warranty.
> > > > f: (360) 435-2636
> > contain
> > > > From: kguns@ >
> > > > To:
> > > > Dear Mr.Nick Klien.
> > an
> > > > Kurt Horvath
> > > > --- In
> > Terry Neal
> > wrote:
> > > > > Hi Kurt,
> > to
> > > > replace
> > Can't
> > > > find
> > > > > Terry
> > panel
> > set
> > > > > > Kurt Horvath
> > > > > > 95 PT-42
> > > > > > Dear Kurt Horvath,
> > > > RV3012M
> > were
> > > > only
> > > > series
> > section
> > regular
> > same.
> > > > models
> > > > > > were:
> > > > > > BAT CAPACITY – AUTO
> > > > > > CHARGE RATE – 80%
> > series.
> > largely
> > > > has
> > that
> > > > enhancements
> > the
> > > > > > cost be?"
> > do not
> > > > a "google"
> > > > available
> > > > freedom
> > model.
> > fine
> > > > if
> > to
> > > > email.
> > > > > > Technical Support
> > > > contain
> > review,
> > the
> > and
> > the
> > model
> > > > or
> > RV3012 M
> > > > be
> > Can
> > > > the
> > > > > > model
> > coach.
> > unites
> > am in
> > time
> > > > to
> > > > > > Kurt Horvath
> > > > > > --- In
> > "Dorn Hetzel"
> > > > > > > From: Nick Klein
> > > > > > > To: "dorn@"
> > > > > > > Dear dorn,
> > > > > > explanation:
> > > > which
> > > > > > were
> > only
> > > > > > used for
> > of
> > > > > > default
> > on "RC7
> > > > > > RC7GS
> > > > > > > Setup Menus".)
> > > > > > Otherwise they
> > and
> > > > > > had no other
> > > > > > models were:
> > > > > > > BAT CAPACITY - AUTO
> > > > > > > CHARGE RATE - 80%
> > sure to
> > > > > > include the
> > > > > > > Technical Support
> > > > > > attachments, is
> > > > confidential
> > > > > > and
> > > > disclosure or
> > > > recipient,
> > > > > > please
> > of the
> > > > > > original
> > > > > > > message.
> > RV3012M and
> > > > > > other
> > > > > > models still
05-30-2008, 12:13
RV 3012 M
Hello All,
on those Cruise Airs-
Can some one explain to me the system under the bus. I do understand there is a compressor of some sort, and a fan. However being 110V, it must be similar to a "window unit A/C" set up?
Where would one get a compressor serviced that is not coming on, (cooling) is it common, specialty?
Who would work on it, its of course not automotive type?
Expensive (compressors)
One I'm looking at needs work on one, not cooling- fan only blows
Thanks for the insite guys!
Stephen
P.C. FL
Birdless (considering acruise-airtype A/C bird)
83PT40
Livingston, Montana
