Fire Hazard
07-01-2010, 09:19
Fire Hazard
Tks
Project
success is in the details
Ken Doyle
ConServe
PO Box 35245
Richmond, VA 23235
direct: 301-908-5735
fax: 804-725-2982
ken.hvac-conserve@...
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On
Behalf Of
Ralph
Sent: Thursday, July 01, 2010 5:16 PM
To: Wanderlodge Forum
Subject: Re: [WanderlodgeForum] Fire Hazard
Ken, not the fresh water tank in your Coach. You have a small space heater
attached to a gray square D thermostat control
Safe travels, Ralph Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
Sender: WanderlodgeForum@yahoogroups.com
Date: Thu, 1 Jul 2010 17:07:26 -0400
To:
ReplyTo: WanderlodgeForum@yahoogroups.com
Subject: RE: [WanderlodgeForum] Fire Hazard
Ernie,
Are heaters used with the 84pt40?
Ken Doyle
ConServe
100 Pine View Dr
Mobjack, VA 23056
h: 804-725-3132
f: 804-725-2982
c: 301-908-5735
Behalf Of
Ernie E
Sent: Friday, June 25, 2010 10:00 AM
Subject: [WanderlodgeForum] Fire Hazard
After removing a fresh water tank on an SP, we found that the freeze
protection mat had scorched the bottom of the tank and the plywood floor. It
had been so hot in the past to scorch a plastic zip tie. Anyone that has this
setup should absolutely discontinue using it. I will post a few photos in the
photo section and will title it fire hazard.
Ernie-83PT40 in Texas
07-01-2010, 09:21
Fire Hazard
Tks
Project
Ken Doyle
ConServe
PO Box 35245
Richmond, VA 23235
fax: 804-725-2982
Behalf Of
brad barton
Sent: Thursday, July 01, 2010 5:12 PM
To: wanderlodgeforum@yahoogroups.com
Ken,
We had those vertical electric heaters on our '84 FC.
Brad (former LXi)
"bbartonwx@hotmail.com"
http://www.bradsweather.com
Ernie,
84pt40?
Ken Doyle
ConServe
100 Pine
View Dr
Mobjack, VA
23056
h:
804-725-3132
f:
804-725-2982
c:
301-908-5735
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]
On Behalf Of Ernie E
the freeze protection mat had scorched the bottom of the tank and the plywood
floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that
has this setup should absolutely discontinue using it. I will post a few photos
in the photo section and will title it fire hazard.
The New Busy is not the old busy. Search, chat and e-mail
from your inbox. Get started.
07-01-2010, 09:50
Fire Hazard
The only reason, come to think of it, right now, is that where the fresh water tank is located in that SP, there is no room for the heaters that the rest of the coaches have. Thus, they installed the mat under the tank.
This tank had many stress cracks and the owner believes it is due to the fact that with the tank resting on the wheel well hump, there was no real support. The tank is not a square job but does have part of it raised to miss the tank. We will be putting a high density pad under that and observing how the tank rests on the wheel well.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
To: "Wanderlodge Forum"
Date: Thursday, July 1, 2010, 4:15 PM
Ken, not the fresh water tank in your Coach. You have a small space heater attached to a gray square D thermostat control
Duncan, Oklahoma
Sender: WanderlodgeForum@ yahoogroups. com
To:
ReplyTo: WanderlodgeForum@ yahoogroups. com
Ernie,
Ken Doyle
ConServe
100 Pine View Dr
Mobjack, VA 23056
h: 804-725-3132
f: 804-725-2982
c: 301-908-5735
ken.hvac-conserve@ att.net
From: WanderlodgeForum@ yahoogroups. com [mailto:Wanderlodge Forum@yahoogroup s.com] On Behalf Of Ernie E
After removing a fresh water tank on an SP, we found that the freeze protection mat had scorched the bottom of the tank and the plywood floor. It had been so hot in the past to scorch a plastic zip tie. Anyone that has this setup should absolutely discontinue using it. I will post a few photos in the photo section and will title it fire hazard.
